Author Topic: VBA or Diesel expressions for layers on?  (Read 3087 times)
hardwired
« on: November 12, 2009, 03:01:53 AM »
Could someone help me out with a diesel expression (and VBA) i can use for a button macro? I want to toggle a layer on or off, nothing more than that but i don't know much diesel..
The layer is LSC-WATERMARK, so its only gonna be like:
If LSC-WATERMARK is ON then, turn OFF LSC-WATERMARK and vice versa (obvious i know)..
I've posted this in the AutoLISP forum to request the AutoLISP and Diesel versions..
Thanks in advance,
ChristopherF
Re: VBA or Diesel expressions for layers on?
« Reply #1 on: November 18, 2009, 03:36:06 PM »
Thanks in advance,
Here's how to do it VBA:
Sub TurnOffLayer()
    If ThisDrawing.Layers.Item("LSC-WATERMARK").LayerOn = True Then
        ThisDrawing.Layers.Item("LSC-WATERMARK").LayerOn = False
    Else
    End If
« Reply #2 on: November 18, 2009, 05:00:10 PM »
I don't see the LISP entry, so here it is in lisp ...
(if (< -1 (cdr(assoc 62 (tblsearch "layer" "LSC-WATERMARK"))))
  (vl-cmdf "-layer" "off" "LSC-WATERMARK" "")
  (vl-cmdf "-layer" "on" "LSC-WATERMARK" "")
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
« Reply #3 on: November 20, 2009, 04:45:31 PM »
Sub TurnOffLayer()
    Else
    End If
Another concise way to toggle a bool value is to simply set the value to what it's Not.
Bobby C. Jones
ChristopherF
« Reply #4 on: November 20, 2009, 07:34:17 PM »
Thanks, learned something new today. It is way more consice.
ThisDrawing.Layers.Item("LSC-WATERMARK").LayerOn = Not ThisDrawing.Layers.Item("LSC-WATERMARK").LayerOn
