Has anyone ever figured out how to change your options in the pipe rule set for the "Match Location" under "Pipe to Pipe Match". We do not use invert, Crown or centerline for our Sanitary but those are the only options that they give you, we use .8d as the method. Is there a way to add this as an option?
