You know guys after doing a little more searching on the net I found a routine which does exactly what I need and wanted to share it with you. I though I recall there being a terrycadd here but not sure. Anyway Terry Miller wherever you are thank you veeeeeerrrry much
; Program Name: TAM.lsp [TAM R2]
; Created By: Terry Miller (Email: terrycadd@yahoo.com)
; (URL: http://web2.airmail.net/terrycad)
; Date Created: 9-20-05
; Function: Matches text, mtext and attribute text with the selected text,
; mtext or attribute text.
; Revision History
; Rev By Date Description
; 1 TM 9-20-05 Initial version. Included TM.lsp, Text Match.
; 2 TM 5-9-07 Added Loop to c:TAM to be able to revise more entities.
; c:TAM - Text and Attribute Match
(defun c:TAM (/ EntList@ EntName^ EntPick@ EntType$ Loop Match$ Next$ Text$)
(princ "\nText and Attribute Match")
(if (setq EntPick@ (nentsel "\nSelect text or attribute text to match: "))
(setq EntName^ (car EntPick@)
EntList@ (entget EntName^)
Match$ (if (assoc 1 EntList@) (cdr (assoc 1 EntList@)))
Loop (if Match$ t nil)
Next$ ""
);setq
(while Loop
(if (setq EntPick@ (nentsel (strcat "\nSelect " Next$ "text or attribute text to replace with \"" Match$ "\": ")))
Text$ (if (assoc 1 EntList@) (cdr (assoc 1 EntList@)))
);setq
(setq Text$ nil)
);if
(if Text$
(setq EntList@ (entmod (subst (cons 1 Match$) (assoc 1 EntList@) EntList@))
EntType$ (cdr (assoc 0 EntList@))
);setq
(entupd EntName^)
(if (or (= EntType$ "MTEXT")(= EntType$ "TEXT"))
(command "REGEN")
);if
);progn
(princ "\nNo text or attribute text selected to replace.")
(setq Loop nil)
);progn
);if
(setq Next$ (if (= Next$ "") "next " ""))
);while
);progn
(princ "\nNo text or attribute text selected to match.")
);if
);defun c:TAM
; c:TM - Text Match
(defun c:TM (/ Cnt# EntList1@ EntName1^ EntList2@ EntName2^ Match$ SS&)
(princ "\nText Match")
(princ "\nSelect text or mtext to match")
(if (setq EntName1^ (car (entsel)))
(setq EntList1@ (entget EntName1^))
);if
(if (or (= (cdr (assoc 0 EntList1@)) "TEXT")(= (cdr (assoc 0 EntList1@)) "MTEXT"))
(setq Match$ (cdr (assoc 1 EntList1@)))
(princ (strcat "\nSelect text or mtext to replace with " Match$))
(if (setq SS& (ssget '((-4 . "<OR")(0 . "MTEXT")(0 . "TEXT")(-4 . "OR>"))))
(command "UNDO" "BEGIN")
(setq Cnt# 0)
(repeat (sslength SS&)
(setq EntName2^ (ssname SS& Cnt#)
EntList2@ (entget EntName2^)
);setq
(setq EntList2@ (subst (cons 1 Match$) (assoc 1 EntList2@) EntList2@))
(entmod EntList2@)
(setq Cnt# (1+ Cnt#))
);repeat
(command "UNDO" "END")
);progn
(princ "\nNo text or mtext selected.")
);if
);progn
);if
);defun c:TM
