Author Topic: cast error with COM Objet and A2010  (Read 7206 times)
Spike Wilbury
Re: cast error with COM Objet and A2010
« Reply #15 on: June 03, 2009, 02:25:02 PM »
I'd rather use something like the findfile LISP function.
then, let see if this works... not fully tested (on A2009) - maybe :)
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Unicode, EntryPoint = "acedFindFile")]
static extern int FindFile(StringBuilder fname, StringBuilder result);
[CommandMethod("TestFind")]
public void testfind()
    Editor ed = doc.Editor;
    StringBuilder sResult = new StringBuilder(128);
    StringBuilder sSearch = new StringBuilder("acad.exe");
    FindFile(sSearch, sResult);
    ed.WriteMessage("{0}", sResult);
« Reply #16 on: June 03, 2009, 02:46:36 PM »
.Net has a findfile, no need to import from a dll.  FYI...
HostApplicationServices.Current.FindFile
Spike Wilbury
« Reply #17 on: June 03, 2009, 02:49:42 PM »
I saw that... and did not tested... :)
Thanks, Tim.
« Reply #18 on: June 03, 2009, 02:50:19 PM »
Thanks, Tim.
I use it in one of my codes.  You're welcome Luis.
Edit:  Added said code.
public static string WillLoad (string FilePath, Database db) {
    string FoundAt = "";
    string[] tempStrAr = FilePath.Split('.');
    string FileExt = tempStrAr[tempStrAr.Length - 1];
[color=red]    try { FoundAt = HostApplicationServices.Current.FindFile(FilePath, db, FindFileHint.Default); }[/color]
    catch {}
    if ( !string.Compare(FoundAt, string.Empty).Equals( 0 ) )
            return FoundAt;
    if (string.Compare(FilePath.Substring(0, 2), "..").Equals(0) || string.Compare(FilePath.Substring(0, 1), ".").Equals(0)) {
        string[] XrPathArray = FilePath.Split('\\');
        string PartialPath = "";
        for (int i = 1; i < XrPathArray.Length; ++i) {
            PartialPath = PartialPath + "\\" + XrPathArray[i];
        FileInfo DwgInfo = new FileInfo(db.Filename);
        string tempFilePath = DwgInfo.DirectoryName + PartialPath;
        try { FoundAt = HostApplicationServices.Current.FindFile(tempFilePath, db, FindFileHint.Default); }
        catch {}
                return FoundAt;
    return string.Empty;
Spike Wilbury
« Reply #19 on: June 03, 2009, 02:52:21 PM »
Thanks, Tim.
10-4
been out of the c# coding for a while until early today, that I played a little bit :)
gile
  • Marseille, France
« Reply #20 on: June 03, 2009, 03:15:49 PM »
Thank you both  :-o
But all this is quite over my head, the only attributes I use at the moment are CommandMethod and LispFunction.
Today, I'm proud I've been able to get the support files search path folders (using COM, Registry reading, ConfigurationManager or DWGPREFIX sysvar) and iterate through them to search a file.
I'll try to study all this, but it's so far from my little LISP knowledge.
xsfhlzh
