Author Topic: Double Click Function on Mouse  (Read 4711 times)
BJordan
« on: April 12, 2006, 07:54:17 AM »
Hi there
I hope that someone can help me.  I am on Autocad 2006 and since Monday I have lost my double click function when it comes to editing text.  At the same time I also can not use the delete key on the keyboard to delete highlighted objects.  Does anyone know how to reset this.
Many thanks
jonesy
  • SuperMod
Re: Double Click Function on Mouse
« Reply #1 on: April 12, 2006, 08:02:19 AM »
Firstly welcome to TheSwamp
I dont use 2006, but in 2005 there is a variable called DBLCLKEDIT that may help you.
this variable can either be on or off. What is it currently set to?
Hope this helps you
Tracey :-)
Sdoman
« Reply #2 on: April 12, 2006, 08:07:11 AM »
My guess is some wayward lisp routine mangled the value of the AutoCAD system variable PICKFIRST.  It should be set to 1 (i think).
Command: PICKFIRST
Enter new value for PICKFIRST <0>: 1
Pickfirst can also be changed via the OPTIONS command > Selection tab > check "Noun/verb selection".
Jürg Menzi
  • Oberegg, Switzerland
« Reply #3 on: April 12, 2006, 10:28:26 AM »
You may find more information concerning mouse handling in this thread.
MENZI ENGINEERING GmbH
MikePerry
« Reply #4 on: April 12, 2006, 12:43:02 PM »
Hi
Try combining the information found in this post and this post...
ID: TS59374 - Quick method to begin editing process
Have a good one, Mike
BJordan
« Reply #5 on: April 13, 2006, 04:57:46 AM »
I would just like to say thankyou for all your help
Pickfirst worked
Thanks again
B
t-bear
« Reply #6 on: April 13, 2006, 01:52:50 PM »
Glad that someone here was able to help you out.....great resource, Huh?  :lmao: :lmao:
Now that you got your feet wet (pun intended here), take a look around.  There's plenty to do here and a TON of great information scattered throughout the forums.  Stop by the "break the Ice" thread in News....tell us your lifes story.  :lmao: :lmao:  If you need something and think it might be floating around here (it probably is) try the "search" option.  It's awsome what's lurking "below the surface"!!!
ELOQUINTET
« Reply #7 on: June 02, 2006, 02:40:24 PM »
bear you forgot to tell him to beware of the cow with big teets  :lmao:
