Arrange what?
Blocks?
Text?
Mleaders?
A few Commands come to mind... Array, Measure, Divide, etc.
This is how I would arrange 23 3D entities in 3D... Like in 2D and in my version linear arrangement prevails - only in Z direction...
See attachment...
See attachment...
Now, above posted code works and with more complex shapes, but only with LWPOLYLINE with straight segments (edges)...
M.R.
After combination, such a minimum area.
http://www.theswamp.org/index.php?topic=46636.0
This is similar to your 11.gif... It uses rotate©, but not mirror... Tested on simple LWPOLYLINES like on posted 11.gif...
Look, similar to 1.png you posted... Also applicable only for LWPOLYLINE in WCS and with straight segments (edges)... You have to accept or hit ENTER if position isn't aligned as should...
Thank you very much! Marko
I'd like to forward your code to “ bbs.mjtd.com” , I will keep the author's name, Do you agree?
As you wish, just be sure I won't be fooled and laugh at...
Thanks, I'm sure not.
太好了,我很高興...
