hi smemo . The lisp i use is from the same post. Your code is too coplicated for me . You have 6 lisp code in a zip file . I want something simple . The original code i use in my first post work fone with NewViewport_Approach_2.lsp.dwg .The problem is when i use it in MY TEMPLATE.dwg the viewports are too small because my scale are (for example 1:50 --> 1000 : 50 in meters). I use meters . I try to change the code in my thirs post and the viewports are big in corect size but the drawing is not in the correct scale, the annotation scale is 1:1 and is lock and not center to the previous selection (is empty. ).
Than you help me with this problem ?
