Code Red => AutoLISP (Vanilla / Visual) => Topic started by: dussla on December 24, 2009, 10:47:55 AM
again hi ~
i imported block .
i would like to explode that block
but that didn;t not explode with many way
can you help again ~~
Here you go. :-)
hi freind
i use cad 2004
how can do that ~~?
hi freind
i use cad 2004
how can do that ~~?
I'm using AutoCad 2008 here at work. The block was scaled differently in the X & Y axises. That's why you couldn't explode it, I think.
Here is the 2004 version.
aha ~~~
thank you good advice
is that impossible in cad 2004
i am thinking explode lisp roution in cad 2004
is that possisble ?
In 2004 you can explode if the X & Y scale are the same but not if they are different.
Then why wasn't dussla, able to explode the block?
I just stated it again.
(setvar "EXPLMODE" 1)
