I found a lisp that can take polyline areas into a new excel session and file. I am trying to also extract out of the elevation with it but no luck as usual lol.
but my real question is to see if this possible once I can get all the data extracted.
I would like to know within a lisp if I can take the data extract it but with the cells next to the imported cell data have two formulas with it?
I know I can do this via excel VBA to AutoCAD, just the other way around I am not sure about.
So if I have a header of Elevation and Area then have the first formula next to the area "=IF(SUM(A2)=0,0,(A3-A2)*AVERAGE(B2:B3))" and the last one after that be "=IF(SUM(A2)=0,0,D2+C3)".
I guess even if I can get one formula next to it I think I could make it work.
Thanks for any input!!
(defun C:ax (/ *error* abks aexc area ar_data asht col en i obj row row_data ss xbks xcel xshs)
(defun *error* (msg)
(vl-position
msg
'("console break"
"Function cancelled"
"quit / exit abort"
(princ "Error!")
(princ msg)
(if (setq ss (ssget (list (cons 0 "LWPOLYLINE")(cons 70 1))))
(setq i -1
(repeat (sslength ss)
(setq en (ssname ss (setq i (1+ i)))
obj (vlax-ename->vla-object en)
ar_data (cons (setq area (vla-get-area obj)) ar_data)
(setq ar_data (reverse ar_data))
(alert "Close Excel File Only")
(setq aexc (vlax-get-or-create-object "Excel.Application")
xbks (vlax-get-property aexc "Workbooks")
abks (vlax-invoke-method xbks "Add")
xshs (vlax-get-property abks "Sheets")
asht (vlax-get-property xshs "Item" 1)
xcel (vlax-get-property asht "Cells")
(vla-put-visible aexc :vlax-true)
(vlax-put-property aexc "UseSystemSeparators" :vlax-false)
(vlax-put-property aexc "DecimalSeparator" (vlax-make-variant "." 8))
(setq row 0
col 1
(vlax-put-property xcel "NumberFormat"
(vlax-make-variant "0.00" 8)
(repeat (length ar_data)
(setq row_data (car ar_data))
(setq row (1+ row))
(vlax-put-property
xcel
"Item"
row
col
(vl-princ-to-string row_data)
(setq ar_data (cdr ar_data))
(vlax-invoke-method
abks
'SaveAs
"C:\\ImportAreas.xls"
-4143
nil
nil
:vlax-false
:vlax-false
1
2
(vlax-release-object xcel)
(vlax-release-object asht)
(vlax-release-object xshs)
(vlax-release-object abks)
(vlax-release-object xbks)
(vlax-release-object aexc)
(setq aexc nil)
(gc)
(gc)
(*error* nil)
(prompt "\n\t\t>>>\tType AX to import areas to Excel\t<<<\n")
Source:
http://www.cadtutor.net/forum/showthread.php?41722-Closed-polyline-Area-values-to-Excel
