Author Topic: Font width Lisp  (Read 6049 times)
One Shot
Font width Lisp
« on: March 11, 2005, 01:37:17 PM »
I am looking for a lisp routine that can change the setting for Simplex. I would like to have the width setting to be at .7
Thank you,
Brad
One Shot
Re: Font width Lisp
« Reply #1 on: March 11, 2005, 02:38:59 PM »
Quote from: One Shot
Thank you,
Brad
;   File Name: Simplex.LSP
    ;   Description: Sets Simplex font to .7 width
(defun C:Simplex (/ SSetwidth)
   (command "-style" "Simplex" "0.000" "0.7" "0" "N" "N" "N")
Can someone please tell me how this should be wrote.  Please point out what I did wrong?[/quote]
DParcon
Font width Lisp
« Reply #2 on: March 11, 2005, 02:55:04 PM »
Try to insert the font name as shown.
 Make sure the font you'll be using is available.
   (command "-style" "Simplex" "Insert Font Name
                      here" "0" "0.7" "0" "N" "N" "N")
 Don
Adesu
Re: Font width Lisp
« Reply #3 on: March 15, 2005, 09:05:37 PM »
Thank you,
Brad
or you can change width factor with this here
; wf is stand for making edit to width factor
;       Design by Ade Suharna <mteybid@yuasabattery.co.id>
;       1 September 2004
;       program no. 60/09/2004
;       edit by Ade Suharna 05/10/2004 1).
(defun c:wf (/ ent info41 opt ed)
  (while                                                ; 1).
  (setq ent (entget (car (entsel)))
        info41 (rtos (cdr (assoc 41 ent)))
  opt
(getreal
  (strcat "\nENTER NEW FACTOR" "<" info41 ">" ":"))
        ed (subst (cons 41 opt)(assoc 41 ent) ent))
  (entmod ed)
One Shot
Font width Lisp
« Reply #4 on: March 17, 2005, 12:49:33 PM »
Can someone modify this lisp work to select all and to allow text lines that stack to be set 1.5 apart.  It also work for text that is in Mtext and for veticle text.
Thank you,
Brad
; 1 September 2004
(while ; 1).
opt
(getreal
(entmod ed)
One Shot
Re: Font width Lisp
« Reply #5 on: March 17, 2005, 05:52:35 PM »
Quote from: Adesu
Thank you,
Brad
;       1 September 2004
  (while                                                ; 1).
     opt
    (getreal
  (entmod ed)
Ade,
I should have asked this before I requested for alteration of your code.  My this code be changed to meet the needs for other users could use it for.
Thank you,
Brad :?:
Adesu
Re: Font width Lisp
« Reply #6 on: March 17, 2005, 08:29:26 PM »
Quote from: Adesu
Thank you,
Brad
;       1 September 2004
  (while                                                ; 1).
     opt
    (getreal
  (entmod ed)
Ade,
Thank you,
Brad :?:
Yes ,please if you want to alter for this code,in this code I prepare special line for edit by,as like this
--------------<snip>-------------------------
;                  One Shot   18/03/2005    2).
--------------<snip>--------------------------
t-bear
Font width Lisp
« Reply #7 on: March 18, 2005, 09:45:18 AM »
Thanks Adesu, for giving permission ... and to Brad for asking.  In the hurry of our jobs, we sometimes forget these amenities.  Good show to both of you .... and thanks for the code!! LOL
Adesu
Font width Lisp
« Reply #8 on: March 20, 2005, 07:04:49 PM »
Quote from: t-bear
You are welcome,thanks.
