Author Topic: CSC: error in Metadata file  (Read 1988 times)
mcollins894
« on: September 09, 2016, 06:36:28 AM »
Hello,
Need solution for below error:
I can't find metadata file in VisualStudio during compilation of project. Can somebody help me to solve the same?
Please post your effective solution.
Thank you in advance.
CADbloke
  • Crash Test Dummy
Re: CSC: error in Metadata file
« Reply #1 on: September 10, 2016, 01:17:13 AM »
Nowhere near enough information. I's say try Stackoverflow.com but they will close your question because you have given us no clues. Try cleaning the solution and rebuilding it.
« Reply #2 on: September 10, 2016, 02:04:51 AM »
djones12998 will post about how great msconcepts is and how it solved his problem.
If you do post djones12998 I am just wondering are you real or a robot?
Kerry already called them out at Acad forums here
Same names from Acad forums except just first letter of first name.
And djones12998 also joined within minutes of mcollins894.
You guys think these are real people or automated?
Maybe I should not mention names in post in case they decided to code in a check to see if people were catching on.
« Last Edit: September 10, 2016, 02:19:10 AM by Jeff H »
« Reply #3 on: September 10, 2016, 06:54:35 AM »
Don't think they are automated but not going to swear to it either. Both accounts used the same IP. I removed them both.
