Author Topic: Lisp not working  (Read 2999 times)
42
Lisp not working
« on: January 18, 2006, 11:19:12 AM »
Not original but it decribs the situation!
When I run the attached lisp file I get this message
Command:
Command:
Command: recd
pspace
Already in paper space.
Command: zoom
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: extents
Command: bad argument type: lselsetp nil
Command:
Command: *Cancel*
Now remember I my lisp skiils are next to nil hence needing help to understand this message.
; Lisp routine to insert a record drawing stamp into an existing A0 or A1 title block,
; clean out any revision note tags and clouding, change to paperspace and zoom to extents
(defun c:recd ()
;obtain original drawing settings
  (setq
    c_blp (getvar "BLIPMODE")
    c_col (getvar "CECOLOR")
    c_lay (getvar "CLAYER")
    c_cmd (getvar "CMDECHO")
    c_til (getvar "TILEMODE")
    c_osm (getvar "OSMODE")
    c_dimzin (getvar "DIMZIN")
    c_qaf (getvar "QAFLAGS")
    c_textstyle (getvar "TEXTSTYLE")
    c_attdia (getvar "ATTDIA")
    c_ctab (getvar "CTAB")
  (LAYLIST)
;find all paperspace layouts
  (setq layoutlist (dictsearch (namedobjdict) "ACAD_LAYOUT"))
  (setq index 1)
  (setq layouts nil)
  (while (<= index (length layoutlist))
         (setq elist (nth (1- index) layoutlist))
         (if (= (car elist) 3) (setq lays (append lays (list(cdr elist)))))
             (setq index (+ index 1)
  (setq lays (cdr (reverse lays)))
  (setq counter 1)
(while (<= counter (length lays))
;set drawing to zoom extents in paperspace
  (setvar "TILEMODE" 0)
  (setvar "CTAB" (nth (1- counter) lays))
  (command "pspace")
  (command "zoom" "extents")
;set required drawing variables
  (setvar "BLIPMODE" 0); Set blipmode off
  (setvar "CECOLOR" "bylayer"); Set current entity colour to bylayer
  (setvar "CMDECHO" 0); Set command line echo to off
  (setvar "DIMZIN" 0)
  (setvar "QAFLAGS" 2)
  (setvar "OSMODE" 0)
; Find if layer "A0RECORD" already exists in drawing. If yes set to current. If no create and set to current.
  (if (tblsearch "layer" "A0RECORD") (command "-layer" "thaw" "A0RECORD" "on" "A0RECORD" "s" "A0RECORD" "") (command "-layer" "m" "A0RECORD" "c" "2" "" ""))
; Create text style "rec_dwg_stamp"
  (command "-style" "rec_dwg_stamp" "ISOCP" "5" "1" "0" "No" "No")
;find all drawing sheet block insertions
  (setq ss (ssget "X" (list (cons 0 "INSERT") (cons 2 "*_HUNTERS") (cons 410 (nth (1- counter) lays)))))
;set drawing sheet offsets
  (setq A0 (list 1115 180 0)
        A1 (list 785 200 0)
        A2 (list 538 180 0)
        A3 (list 364 180 0)
;determine drawing sheet size and set offset insertion co-ordinates for record drawing stamp
  (if (/= (sslength ss) 1) quit)
  (cond ((= (cdr (assoc 2 (entget (ssname ss 0)))) "A0_sht") (setq r_off A0))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "A0_SHT") (setq r_off A0))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "A0_Sht") (setq r_off A0))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "a0_Sht") (setq r_off A0))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "a0_sht") (setq r_off A0))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "a0_SHT") (setq r_off A0))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "WORC_A0_SHT") (setq r_off A0))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "A0_Hunters") (setq r_off A0))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "A1_sht") (setq r_off A1))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "A1_SHT") (setq r_off A1))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "A1_Sht") (setq r_off A1))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "a1_SHT") (setq r_off A1))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "a1_sht") (setq r_off A1))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "a1_Sht") (setq r_off A1))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "WORC_A1_SHT") (setq r_off A1))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "A1_Hunters") (setq r_off A1))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "A2_sht") (setq r_off A2))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "A3_sht") (setq r_off A3))
        ((= (cdr (assoc 2 (entget (ssname ss 0)))) "A3_Hunters") (setq r_off A3))
        ((= (sslength ss) 1) (print "Not a Hunters Standard Titleblock"))
;retrieve insertion co-ordinates of titleblock to variable tb_ins
  (setq tb_ins (cdr (assoc 10 (entget (ssname ss 0)))))
;create new co-ordinates for record stamp insertion
  (setq r_off1 (list (+ (car r_off) (car tb_ins) -65) (+ (cadr r_off) (cadr tb_ins) -15) (+ (caddr r_off) (caddr tb_ins) 0))
        r_off2 (list (+ (car r_off) (car tb_ins) 45) (+ (cadr r_off) (cadr tb_ins) 20) (+ (caddr r_off) (caddr tb_ins) 0))
        r_off1a (strcat (rtos (car r_off1)) "," (rtos (cadr r_off1)) "," (rtos (caddr r_off1)))
        r_off2a (strcat (rtos (car r_off2)) "," (rtos (cadr r_off2)))
; insert mtext record drawing stamp
  (command "-mtext" r_off1a "j" "tl" r_off2a "THE INFORMATION CONTAINED
WITHIN THIS AS BUILT DRAWING
HAS BEEN CONFIRMED BY THE
MAIN CONTRACTOR 'MOWLEM' AS
BEING AN ACCURATE RECORD
" "RECORD" "DRAWING" "")
;create a list of all revision clouds contained on paperspace if they exist
  (setq pl_list (ssget "X" (list (cons 0 "LWPOLYLINE") (cons 410 (nth (1- counter) lays)))))
  (setq count 1)
  (setq cloud_list nil)
  (if (/= pl_list nil) (while (<= count (sslength pl_list))
                       (setq elist (ssname pl_list (1- count)))
                       (if (> (length (entget elist)) 60) (setq cloud_list (append cloud_list (list(cdr (assoc -1 (entget elist)))))))
                       (setq count (+ count 1))
  (setq count 1)
  (if (/= (length cloud_list) 0)
      (while (<= count (length cloud_list))
            (entdel (nth (1- count) cloud_list)) ;erase revision clouds contained in cloud_list
      (print "No revision clouds found!")
;find all revision tag block insertions
  (setq rev_list (ssget "X" (list (cons 0 "INSERT") (cons 2 "revision_tag") (cons 410 (nth (1- counter) lays)))))
  (if (= rev_list nil) (setq rev_list (ssget "X" (list (cons 0 "INSERT") (cons 2 "revision_tag") (cons 410 (nth (1- counter) lays))))))
;erase revision tags
  (setq count 1)
  (if (/= (length rev_list) 0)
      (while (<= count (sslength rev_list))
              (setq elist (ssname rev_list (1- count)))
              (entdel (cdr (assoc -1 (entget elist))))
      ) (print "No revision tags found!")
; Find if layer "A0TEXT-NOTE" already exists in drawing. If yes set to current. If no create and set to current.
  (if (tblsearch "layer" "A0TEXT-NOTE") (command "-layer" "thaw" "A0TEXT-NOTE" "on" "A0TEXT-NOTE" "s" "A0TEXT-NOTE" "") (command "-layer" "m" "A0TEXT-NOTE" "c" "2" "" ""))
;find last revision note block insertion and attribute data
  (setq rev_note (entget (ssname (ssget "X" (list (cons 0 "INSERT") (cons 2 "rev_note") (cons 410 (nth (1- counter) lays)))) 0)))
  (if (= rev_note nil) (setq rev_note (entget (ssname (ssget "X" (list (cons 0 "INSERT") (cons 2 "REV_NOTE"))) 0))))
  (setq att_list (entget (entnext (cdr (assoc -1 rev_note)))))
  (while (= (cdr (assoc '0 att_list)) "ATTRIB") (cond ((= (cdr (assoc 2 att_list)) "DATE") (setq att_date (cdr (assoc 1 att_list))))
                                                      ((= (cdr (assoc 2 att_list)) "LETTER") (setq att_letter (cdr (assoc 1 att_list))))
                                                      ((= (cdr (assoc 2 att_list)) "INITIALS") (setq att_init (cdr (assoc 1 att_list))))
                                                      ((= (cdr (assoc 2 att_list)) "LINE-1") (setq att_line1 (cdr (assoc 1 att_list))))
                                                      ((= (cdr (assoc 2 att_list)) "LINE-2") (setq att_line2 (cdr (assoc 1 att_list))))
                                                      ((= (cdr (assoc 2 att_list)) "LINE-3") (setq att_line3 (cdr (assoc 1 att_list))))
         (setq att_list (entget (entnext (cdr (assoc -1 att_list)))))
  (setq rev_ins (cdr (assoc 10 rev_note)))
;create new revision note 3.5mm down from last entry of last revision note
  (cond ((/= att_line3 "") (setq ins_y -10.5))
        ((/= att_line2 "") (setq ins_y -7.0))
        ((/= att_line1 "") (setq ins_y -3.5))
  (setq new_ins (subst (+ (cadr rev_ins) ins_y) (cadr rev_ins) rev_ins))
  (setvar "attdia" 0); turn off attribute dialogue box
  (setq new_insa (strcat (rtos (car new_ins)) "," (rtos (cadr new_ins)) "," (rtos (caddr new_ins))))
  (setq year (substr (rtos (getvar "CDATE") 2 0) 3 2)
        month (substr (rtos (getvar "CDATE") 2 0) 5 2)
        day (substr (rtos (getvar "CDATE") 2 0) 7 2)
        rev_date (strcat day (substr att_date 3 1) month (substr att_date 3 1) year)
  (if (<= (ascii att_letter) 57) (setq rev_letter (if (= (strlen (itoa (+ (atoi att_letter) 1))) 1) (strcat "0" (itoa (+ (atoi att_letter) 1))) (itoa (+ (atoi att_letter) 1)))) (setq rev_letter (chr (+ (ascii att_letter) 1))))
  (command "-insert" "rev_note" new_insa "1" "1" "0" "RECORD DRAWING" rev_letter rev_date "IS" "" "")
;set titleblock revision to match new revision note
  (setq att_list2 (entget (entnext (ssname ss 0))))
  (while (= (cdr (assoc '0 att_list2)) "ATTRIB") (cond ((= (cdr (assoc 2 att_list2)) "CURRENT-REV") (entmod (subst (cons '1 rev_letter) (assoc '1 att_list2) att_list2))))
         (setq att_list2 (entget (entnext (cdr (assoc -1 att_list2)))))
  (setq counter (+ counter 1))
  (command "regenall")
  (RESTORE_VAR)
(Defun RESTORE_VAR ()
;  (command "-layer" "thaw" c_lay "on" c_lay "")
  (setvar "CLAYER" c_lay)
;  (command "-layer" "thaw" "*" "on" "*" "unlock" "*" "freeze" f_list "off" o_list "lock" l_list "")
  (setvar "BLIPMODE" c_blp)
  (setvar "CECOLOR" c_col)
  (setvar "CMDECHO" c_cmd)
  (setvar "TILEMODE" c_til)
  (setvar "OSMODE" c_osm)
  (setvar "DIMZIN" c_dimzin)
  (setvar "QAFLAGS" c_qaf)
  (setvar "TEXTSTYLE" c_textstyle)
  (setvar "ATTDIA" c_attdia)
  (setvar "CTAB" c_ctab)
(defun laylist ()
:retrieves list of entries in Layer Table
  (setq x nil)
  (while (setq p "" d (tblnext "layer" (null d)))
    (setq x (append x (list d)))
;creates list of layer names frozen
  (setq count 1)
  (setq froz_list nil)
  (while (<= count (length x))
    (setq elist (nth (1- count) x))
    (if (= (cdr (assoc 70 elist)) 1) (setq froz_list (append froz_list (list(cdr (assoc 2 elist))))))
    (if (= (cdr (assoc 70 elist)) 5) (setq froz_list (append froz_list (list(cdr (assoc 2 elist))))))
;creates list of layer names locked
  (setq count 1)
  (setq lock_list nil)
    (if (= (cdr (assoc 70 elist)) 4) (setq lock_list (append lock_list (list(cdr (assoc 2 elist))))))
    (if (= (cdr (assoc 70 elist)) 5) (setq lock_list (append lock_list (list(cdr (assoc 2 elist))))))
;creates list of layer names turned off
  (setq count 1)
  (setq off_list nil)
    (if (< (cdr (assoc 62 elist)) 0) (setq off_list (append off_list (list(cdr (assoc 2 elist))))))
;creates string of layer names frozen
  (setq count 1)
  (setq f_list "")
  (while (<= count (length froz_list))
    (setq elist (nth (1- count) froz_list))
    (setq f_list (strcat f_list "," elist))
  (setq f_list (substr f_list 2))
;creates string of layer names locked
  (setq count 1)
  (setq l_list "")
  (while (<= count (length lock_list))
    (setq elist (nth (1- count) lock_list))
    (setq l_list (strcat l_list "," elist))
  (setq l_list (substr l_list 2))
;creates string of layer names turned off
  (setq count 1)
  (setq o_list "")
  (while (<= count (length off_list))
    (setq elist (nth (1- count) off_list))
    (setq o_list (strcat o_list "," elist))
  (setq o_list (substr o_list 2))
It works on some of our drawings but not others The common factor is different drawing sheets
Alastair Mallett Autodesk Certified Professional
Technical Director
Hunters South Architects
Re: Lisp not working
« Reply #1 on: January 18, 2006, 11:37:09 AM »
I'm just going off the error message you supplied.  I have seen this when you try and process a selection set when one doesn't occure.  Change this line to:
to
(if (or (not ss) (/= (sslength ss) 1)) quit)
This is now saying that if ss doesn't exist or then length doesn't equal 1, then quit.
LE
« Reply #2 on: January 18, 2006, 11:46:45 AM »
to
Lisp function QUIT .... requires: (quit)
_$ (if (/= (sslength ss) 1) quit)
error: bad argument type: lselsetp nil
_1$
_$ (if (or (not ss) (/= (sslength ss) 1)) quit)
#<SUBR @05b873c0 QUIT>
_$
$ (if (or (not ss) (/= (sslength ss) 1)) (quit))
error: quit / exit abort
_1$
