Author Topic: Text explode  (Read 4391 times)
77077
Text explode
« on: November 29, 2014, 02:59:36 AM »
Hi guys
I want explode text to curve .
I know ET tools can do this (txtexp) ,but the effect is poor.
I use lisp can do this too, but effect is poor too.
  1.
  2. (defun c:xt (/ bz ss n lvs lss lvp lvl lul ent luu)
  3. (prompt "\nchoose text to explode")
  4. (while (setq ss (ssget ":S" '((0 . "*text"))))
  5. (setvar "cmdecho" 0) (command "undo" "be") (setvar "mirrtext" 1)
  6. (command "zoom" "e")
  7. (setq bz (getvar "osmode")) (setvar "osmode" 0)
  8. (setq lvs (getvar "viewsize") lss (getvar "screensize") lvp (getvar "viewctr")
  9.       lvl (list (list (- (car lvp) (* 0.5 (* lvs (/ (car lss) (cadr lss))))) (- (cadr lvp) (* 0.5 lvs)))
  10.                    (list (+ (car lvp) (* 0.5 (* lvs (/ (car lss) (cadr lss))))) (+ (cadr lvp) (* 0.5 lvs))))
  11.           lul (list (caar lvl) (cadadr lvl)) n 0)
  12.   (setq ent (ssname ss n))
  13.   (setq luu (strcat (getenv "Temp") "\\textb.wmf"))
  14.   (command "mirror" ent "" lvp "@0,1" "y"
  15.   "wmfout" luu ent "" "erase" ent ""
  16.   "wmfin" luu lul "2" "" ""
  17.   "mirror" (entlast) "" lvp "@0,1" "y"
  18.   "explode" (entlast) "erase" (ssget "p") "r" "w"
  19.   (polar (car lvl) (* 0.25 pi) (max (abs (/ lvs (cadr lss))) (abs (/ (* lvs (/ (car lss) (cadr lss))) (car lss)))))
  20.   (cadr lvl) "") ;;end_command
  21.   (setq n (+ n 1))
  22. )
  23. (command "zoom" "p")
  24. (setvar "mirrtext" 0) (setvar "osmode" bz) (command "undo" "e")
  25. )
  26. )
  27.
This is perfect , who can help optimized code ? Thanks!!!
« Last Edit: November 29, 2014, 03:04:02 AM by 77077 »
David Bethel
Re: Text explode
« Reply #1 on: November 29, 2014, 07:06:31 AM »
If you use .shx fonts,   search for XSHP.LSP from Upper Canada Software.  -David
R12 Dos - A2K
77077
Re: Text explode
« Reply #2 on: November 29, 2014, 10:02:34 AM »
Thanks David.  I download it ,test , But  don't succeed .  need .shp file , ? I Convert *.shx to .shp ,  err...... oh ! bad methods.
« Last Edit: November 30, 2014, 08:59:51 PM by 77077 »
Re: Text explode
« Reply #3 on: November 30, 2014, 07:09:04 AM »
You could try this by SEANT  :-)
77077
Re: Text explode
« Reply #4 on: November 30, 2014, 08:16:33 AM »
Thanks lee, I'll take a look.
David Bethel
Re: Text explode
« Reply #5 on: December 01, 2014, 07:04:03 AM »
Looks like something has broken XHSP.LSP in newer releases of Autolisp.   Sorry.
R12 Dos - A2K
hmspe
Re: Text explode
« Reply #6 on: December 01, 2014, 08:49:43 AM »
The issue in xshp.lsp appears to be in
  1. (lambda()))))))                         ;15 = Illegal cmd.
Change this to
  1. (lambda() (setq temp temp)))))))                                ;15 = Illegal cmd.
and the code appears to work.  From a very brief test it appears that the SHP file has to have been created from the SHX file before you run XSHP.LSP.
It looks to me like the text originally posted was truetype, nor SHX.
"Science is the belief in the ignorance of experts." - Richard Feynman
