Yes and NO
Mostly no...the sample increment always projects perpendicular to the baseline, the Sample Line group, the thing whose end points you changed are variable...
And now you have moved them oblique to the alignment...
So, you will NOT get a normal section at that station.
However, if you build all of the corridor surfaces and then do a Sample More Sources for your SLG and THEN you should see the surfaces from the assemblies, you just will not get your normal assembly sections and labels per your code set style....
However you may want to create a separate SLG just for this oblique station section...
