Author Topic: Best way to grab block to edit  (Read 2576 times)
David Hall
  • Automatic Duh Generator
« on: November 30, 2010, 11:05:51 AM »
I am trying to grab a block I just inserted to edit the attributes.  This works, but I know there has got to be a better way.
Any suggestions on best way to grab the block.  I do know the ObjectId, as I just inserted it.
if (bt.Has(strBlock))
foreach (ObjectId entId in CurrentSpaceBTR)
Entity ent = tr.GetObject(entId, OpenMode.ForRead) as Entity;
if (ent != null)
BlockReference br = ent as BlockReference;
if (br != null)
BlockTableRecord bd =
(BlockTableRecord)tr.GetObject(
br.BlockTableRecord,
OpenMode.ForRead
if (bd.Name.ToUpper() == strBlock)
foreach (
ObjectId arId in br.AttributeCollection
DBObject obj = tr.GetObject(arId, OpenMode.ForRead);
AttributeReference ar = obj as AttributeReference;
if (ar != null)
ar.UpgradeOpen();
switch (ar.Tag)
case "TITLE1":
ar.TextString = idAttlist["TITLE1"];
break;
case "TITLE2":
ar.TextString = idAttlist["TITLE2"];
break;
case "TECH":
ar.TextString = idAttlist["TECH"];
break;
case "TECHDATE":
ar.TextString = idAttlist["TECHDATE"];
break;
ar.DowngradeOpen();
Re: Best way to grab block to edit
« Reply #1 on: November 30, 2010, 11:25:28 AM »
How did you insert it?  If you inserted it though code that comes before, then I would just use what was returned when you inserted it.  I would not want to step through the current layout's entities each time I inserted a block, just to fill out attributes.
David Hall
« Reply #2 on: November 30, 2010, 12:16:48 PM »
I agree, but I cant seem to grab the insertion.
David Hall
« Reply #3 on: November 30, 2010, 12:22:50 PM »
This is how I inserted the block
ObjectId tmpBlockId = bt[strBlock];
BlockTableRecord blkDefRecord = (BlockTableRecord)tr.GetObject(tmpBlockId, OpenMode.ForRead);
//BlockReference br = new BlockReference(ppr.Value, tmpBlockId);
BlockReference br = new BlockReference(insPt, tmpBlockId);
CurrentSpaceBTR.AppendEntity(br);
if (blkDefRecord.HasAttributeDefinitions)
foreach (ObjectId idAtt in blkDefRecord)
AttributeDefinition attDef = tr.GetObject(idAtt, OpenMode.ForRead) as AttributeDefinition;
if (attDef != null)
AttributeReference attRef = new AttributeReference();
attRef.SetAttributeFromBlock(attDef, br.BlockTransform);
br.AttributeCollection.AppendAttribute(attRef);
tr.AddNewlyCreatedDBObject(attRef, true);
tr.AddNewlyCreatedDBObject(br, true);
else
string sourceFileName = string.Concat(strPath, strBlock, ".dwg");
try
using (Database tempDb = new Database(false, true))
tempDb.ReadDwgFile(sourceFileName, FileShare.Read, true, null);
db.Insert(strBlock, tempDb, false);
if (attDef != null)
attRef.SetPropertiesFrom(attDef);
catch (Autodesk.AutoCAD.Runtime.Exception e)
ed.WriteMessage(e.Message);
LE3
« Reply #4 on: November 30, 2010, 12:28:42 PM »
any .Commit() call somewhere?
could be....
David Hall
« Reply #5 on: November 30, 2010, 12:32:52 PM »
Hey LE, yea its further down.  I didnt post the whole thing as it takes up a lot of space.  Ill post the whole thing.
using System;
//using System.Collections;   //Dont need this as we are using Generics
using System.Linq;
using System.Text;
using System.IO;
using Autodesk.AutoCAD.GraphicsInterface;
using System.Windows.Forms;
namespace TEPTITLE
    public class TEPTITLE
        [CommandMethod("TEPTitle")]
        public static void TEPTitleBlock()
            int cbo1int;
            TitleBlock.TepTitleBlock frm = new TitleBlock.TepTitleBlock();
            Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(frm);
            cbo1int = frm.BlockTypeIndex;
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            string strUser = System.Environment.UserName.ToUpper();
            DateTime dateToday = DateTime.Today;
            DateTime dateOnly = dateToday.Date;
            string strDate = dateOnly.ToString("d");
            Point3d insPt = new Point3d(0, 0, 0);
            string strBlock = null;
            #region TitleChoice
            switch (cbo1int)
                case 0:
                    strBlock = "TEP-INFO";
                    break;
                case 1:
                    strBlock = "VTEP-INFO";
                    break;
                case 2:
                    strBlock = "TEP-CIP";
                    break;
                case 3:
                    strBlock = "VTEP-CIP";
                    break;
                case 4:
                    strBlock = "UES-INFO";
                    break;
                case 5:
                    strBlock = "VUES-INFO";
                    break;
                case 6:
                    strBlock = "UES-CIP";
                    break;
                case 7:
                    strBlock = "VUES-CIP";
                    break;
                default:
                    break;
            #endregion
            #region SwitchUser
            switch (strUser)
                case "UA02038":
                    strUser = "D.HALL";
                    break;
                case "UA00648":
                    strUser = "D.LIVINGSTONE";
                    break;
                case "UA00071":
                    strUser = "G.TAYLOR";
                    break;
                case "UA05645":
                    strUser = "N.MERCHANT";
                    break;
                case "UA00664":
                    strUser = "P.OLIVAS";
                    break;
                case "UA50151":
                    strUser = "L.RICHARDSON";
                    break;
                case "UA50270":
                    strUser = "A.DOMINGUEZ";
                    break;
                case "UA50050":
                    strUser = "D.LOPEZ";
                    break;
                case "UA50463":
                    strUser = "C.PADILLA";
                    break;
            #endregion
            IDictionary<string, string> idAttlist = new Dictionary<string, string>();
            //idAttlist.Add("TagName", "StringValue");
            idAttlist.Add("TITLE1", "AC SCHEMATIC");
            idAttlist.Add("TITLE2", "DC SCHEMATIC");
            idAttlist.Add("TECH", strUser);
            idAttlist.Add("TECHDATE", strDate);
            string strPath = @"S:\TITLEBLOCKS\";
                BlockTableRecord CurrentSpaceBTR = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                #region InsertBlockFirstTime
                            if (attDef != null)
                else
                    try
                                if (attDef != null)
                #endregion
                #region EditAttributes
                        if (ent != null)
                            if (br != null)
                                OpenMode.ForRead
                                    foreach (
                                        if (ar != null)
                                            ar.UpgradeOpen();
                                            switch (ar.Tag)
                                                case "TITLE1":
                                                    break;
                                                case "TITLE2":
                                                    break;
                                                case "TECH":
                                                    break;
                                                case "TECHDATE":
                                                    break;
                                            ar.DowngradeOpen();
                #endregion
                tr.Commit();
David Hall
« Reply #6 on: November 30, 2010, 12:34:24 PM »
This is all proof of concept code, so paths are hard-pathed, the IDictionary is being populated with bogus text, the only true variable is the combobox on the form where you can choose b/t 8 different titleblocks
Jeff H
« Reply #7 on: November 30, 2010, 12:51:00 PM »
Do you want a example to edit the attributes reference as you insert the block reference
David Hall
« Reply #8 on: November 30, 2010, 01:27:13 PM »
Tim you are a genius!  Here is Tim's solution to my brain block!
if (!bt.Has(strBlock))
                    try
                         CantInsert = true;
                if (CantInsert) return;
                        if (attDef != null)
                            switch (attRef.Tag)
                                case "TITLE1":
                                    attRef.TextString = idAttlist["TITLE1"];
                                    break;
                                case "TITLE2":
                                    attRef.TextString = idAttlist["TITLE2"];
                                    break;
                                case "TECH":
                                    attRef.TextString = idAttlist["TECH"];
                                    break;
                                case "TECHDATE":
                                    attRef.TextString = idAttlist["TECHDATE"];
                                    break;
Jeff, I was able to edit the attributes, I was just doing it VERY inefficiently, and Tim helped set me straight.
