yeah , lsp and odc are in the search path only. but it shows the error as
" OBJECTDCL COULD NOT ABLE TO FOUND"
i am thinking that the problem is related to objectdcl.arx.
You also appear to be mixing OpenDCL and ObjectDCL
opendcl 4.0
objectdcl2004.arx ...
objectdcl2004.arx <<<<<<<< The ARX for AC2004 is
OpenDCL.16.ARXIf you add something like this to the top of your file, the correct ARX will be loaded.
Note that
OpenDCL_ARXLoader.LSP must be found on the CAD search path.
... only needs to be run once per session.
ADDED: or the .ARX file can be loaded manually or at Startup ..
;; Ensure the OpenDCL.##.ARX is loaded.
(OR (VL-SYMBOL-VALUE 'ODCL_GETVERSIONEX)
(AND (SETQ tmpfn (FINDFILE "OpenDCL_ARXLoader.LSP"))
(LOAD tmpfn (STRCAT "Failed to load :- " tmpfn))
(ALERT (STRCAT "Failed to load OpenDCL_ARXLoader.LSP"))
(EXIT)
(PROMPT (STRCAT "\n CommandLine : < YOUR COMMAND NAME> [Build 20070503 kwb] "
"ODCL.Ver:"
(ODCL_GETVERSIONEX)
" \n"
can u help me to solve
regards
viva
Yes.
