Author Topic: Viewport problem.  (Read 2523 times)
hudster
Viewport problem.
« on: September 29, 2004, 07:42:01 AM »
I'm having problems with viewports on our clients drawings.
I'm having to alter the scales of his drawings, but each time I click into a viewport it zooms to extents.  Anyone have an idea why it's doing this, and how to stop it.
Cheers in advance
Andy
***edit***
Even if I delete the viewport and create a new one, it still zooms to extents.
CADaver
Viewport problem.
« Reply #1 on: September 29, 2004, 07:42:32 AM »
UCSFOLLOW, I think.
hudster
Viewport problem.
« Reply #2 on: September 29, 2004, 07:44:43 AM »
nope, changed the variable and it still does it.
CADaver
Viewport problem.
« Reply #3 on: September 29, 2004, 07:49:25 AM »
Quote from: Hudster
Crud, now I'm gonna have to go look. sorry.
SMadsen
Viewport problem.
« Reply #4 on: September 29, 2004, 07:59:16 AM »
I'm guessing that you're referring to floating viewports in paperspace, Hudster? If so, you need to set UCSFOLLOW in each viewport.
hudster
Viewport problem.
« Reply #5 on: September 29, 2004, 08:24:51 AM »
Aye that did it.
Sorry Cadaver, you were right.
I had to change the UCS follow and restore the ucs to world before it stopped zomming out, but I learned something new today.
CADaver
Viewport problem.
« Reply #6 on: September 29, 2004, 08:42:37 AM »
Quote from: Hudster
Aye that did it.
Kewl.
