Code Red => AutoLISP (Vanilla / Visual) => Topic started by: dudi_dk on June 29, 2016, 06:22:33 AM
Hello,
I need to start AutoCAD from a Batch file.
I need to be able to start few AutoCAD sessions from a batch file.
I need to be able to add a "/b" (For running a script on the opened file) to the AutoCAD "Calling" in the batch file.
If I use …
START "C:\Program Files\Autodesk\AutoCAD 2015\acad.exe" "C:\Users\dudik\Desktop\111.dwg" "/nologo"
Then the AutoCAD does not read the /nologo
If I use …
Then I can not add another session of AutoCAD (in order to have two AutoCAD sessions open)
Thanks in advance,
David
If you want speed, then don't use acad.exe. Consider using the Core Console (http://through-the-interface.typepad.com/through_the_interface/2012/02/the-autocad-2013-core-console.html).
