Code Red => AutoLISP (Vanilla / Visual) => Topic started by: aswin on March 21, 2017, 04:06:15 AM
Hi friends...
is there any lisp to offset a line as per attachment ?
Is there a ratio or formula that is consistent?
Use this tool (http://www.lee-mac.com/dynamicoffset.html) from Lee Mac, and adjust the offset factor.
THIS (https://www.theswamp.org/index.php?topic=24688.msg297553#msg297553) one too.
And maybe http://www.cadtutor.net/forum/showthread.php?88234-Multi-Offset-with-Different-Distances&p=606023&viewfull=1#post606023
How about knurling lines?
;;; inserts, moves and rotates vertical knurling lines for side view of cylinder
(defun c:233 (/ di ip l n oort p1 p2 r ss u u1)
(command "_.undo" "begin")
(setq l (getdist "\n Knurling line length: ")
r (/ (getdist "\n Diameter: ") 2.0)
n (getint "\n Number of knurling lines visible in side view: ")
u (/ pi n)
ip (list 0 0 0)
u1 u
ss (ssadd)
oort (getvar "orthomode")
(repeat (- n 1)
(setq di (- r (* r (cos u1)))
p1 (polar ip 0 di)
p2 (polar p1 (* pi 0.5) l)
u1 (+ u1 u))
(entmake (list (cons 0 "LINE")(cons 10 p1)(cons 11 p2)))
(ssadd (entlast) ss)
(setvar "orthomode" 0)
(command "move" ss "" ip pause)
(command "rotate" ss "" (getvar "lastpoint") pause)
(setvar "orthomode" oort)
(command "_.undo" "end")
(princ (strcat "\n Circle radius = " (rtos r 2 3)))
Awesome
Thanks GDF, laziness made me write it some time ago.
Thanks a lot friends.. really helpful lisps... :-D
