Author Topic: Labels connected to Linework  (Read 6111 times)
MSTG007
« Reply #15 on: June 24, 2004, 11:08:38 AM »
nice.....  really nice...
can the line be changed to a Quick Leader?
Civil3D 2020
MSTG007
« Reply #16 on: June 24, 2004, 11:14:47 AM »
but what i just did which works is this...
It labels my line my layer name!
Ex.    LAYER NAME   -  EX-WATER
Then i use find and replace under edit,
EX-  to find
EXISTING  to replace
now with the label I have EXISTING WATER for a label!!!!!
my layer names are
EX-WATER
EX-PAVEMENT
EX-CONCRETE
EX-CONCRETE-WALK
EX-CURB
ETC.
Civil3D 2020
« Reply #17 on: June 25, 2004, 02:15:48 PM »
Revised..
(defun c:label_prop (/ usercmd useros ent lname pt pt2 offset
                     ofsdir txtjust dwg_ht )
  (setvar "CMDECHO" 0)
  (setq useros (getvar "osmode"))
  (setvar "osmode" 0)
  (if (setq ent (entsel "\Select an entity to label."))
      (setq pt     (cadr ent)
            lname  (cdr (assoc 8 (entget (car ent)))) ;LAYER NAME
            offset 2 ; amount of box offset from text
      (if (and (member (strcase(substr lname 1 3)) '("EX-" "EX_"))
               (> (strlen lname)3))
        (setq lname (strcat "Existing " (substr lname 4)))
      (if (setq pt2 (getpoint pt "\nSelect Placement Point: "))
          (command "_.LINE" pt pt2 "")
          (if (>= (car pt2) (car pt)) ; line is left to right
            (setq txtjust "ML"
                  ofsdir offset
            (setq txtjust "MR"
                  ofsdir  (- offset)
          (setvar "osmode" 0)
          (setq
            dwg_ht
             (cdr (assoc 40 (tblsearch "style" (getvar "textstyle")))
          (if (= dwg_ht 0)
            (command "text" "J" txtjust (polar pt2 0 ofsdir) "" 0 lname)
            (command "text" "J" txtjust (polar pt2 0 ofsdir) 0 lname)
          ) ; endif
          (tbox (entlast) offset)
  (setvar "CMDECHO" usercmd)
  (setvar "osmode" useros)
;;           Draw a pline box around line text
(defun tbox (te sf / e1 tb ll ur ul lr el pt plw)
  (setq plw (getvar "PlineWid")) ; width of Poly Line
  (if (/= plw 0)
      (setq plw (getint (strcat "Enter Pline Width <" (rtos plw) ">:")))
      (if (= plw nil)
        (setq plw 0)
      (setvar "PlineWid" plw)
  (setq e1 (entget te))
  (= (setq typ (cdr (assoc 0 e1))) "TEXT")
  (command "ucs" "Entity" te)
  (setq tb (textbox e1)
        ll (car tb)
        ur (cadr tb)
        ul (list (car ll) (cadr ur))
        lr (list (car ur) (cadr ll))
  (command "._pline" ll lr ur ul "c")
  (setq el (entlast))
  (setq pt (polar ll (angle ll lr) (* (distance ll lr) 2)))
  (command "._offset" sf el pt "")
  (entdel el)
  (command "ucs" "w")
« Reply #18 on: June 25, 2004, 03:00:39 PM »
And borrowing from Stig I revised to this:
                     ofsdir txtjust dwg_ht laytag lname)
;; LAYERTRANSVALUES returns an assoc list in
;; the format: (object_layer label text_layer)
(defun layerTransValues ()
  ;;  Tag  Replacement
  '(( "EX_" "Existing")
    ("EX-" "Existing")
    ;; add to list when needed
    ;;  Tag MUST be in upper case
  (setvar "osmode" 0)
      (setq pt     (cadr ent)
      ;;  Layer name check  =============
      (foreach laytag (layerTransValues)
        (if (and (= (strcase(substr lname 1 (strlen (car laytag)))) (car laytag))
                 (> (strlen lname)(strlen (car laytag))))
          (setq lname (strcat (cadr laytag) " "
                        (substr lname (1+(strlen (car laytag))))))
            (setq txtjust "ML"
                  ofsdir offset
            (setq txtjust "MR"
                  ofsdir  (- offset)
          (setvar "osmode" 0)
          (setq
            dwg_ht
          (if (= dwg_ht 0)
          ) ; endif
  (if (/= plw 0)
      (if (= plw nil)
        (setq plw 0)
        ll (car tb)
        ur (cadr tb)
  (setq el (entlast))
  (entdel el)
  (command "ucs" "w")
