Hi Mike
Here is a snapshot of the Prospector. The surface is invalid because we updated the original surface
with a road by corridor that is now built. I tried your suggestion about adding a rect. poly and it Fatal Error
over and over. I have done a audit. The surface I'm trying to delete has the tri. symbol showing a shortcut.
My question is once you have promoted a data shortcut in a new dwg is there no way to erase it?
This started
in this order. One, fresh dwg no surfaces. Added by promotion into blank dwg the older surface. A grading group was
then created. Then the data shortcut folder was deleted by unknown source. Reset working folder. A new surface
was created that added a surface by corridor and that made a overall new surface to do additional grading of lots from
(making the older overall surface invalid to use for grading anymore).
That dwg with newer surface was added to working folder. The grading dwg then had 2 overall surfaces. The grading
object then were updated to target the new overall surface. I then tried to delete the older overall surface. It had
in rt. click no option to delete. So, I isolated that surface and tried to delete the older overall surface. It died and went to Hell.
Also, in the working folder, it wasn't present, so I put it back in. It still didn't allow me to remove it.
So, it is so screwed up now. I see that the grading groups, even with the updated target surface, can't be exported that
worked. I would just start again with the new surface and just rebuild the grading groups again in my site.
I the surface is truly LIVE, i.e. no longer a data reference....draw a rectangular polyline
add to the surface definition
Rebuild the surface
Select from screen, Press Delete Key
The surface will go away
Follow previous advice for future success.
