How does it work? Here's a step-by-step rundown:* Simplify your model down to 3D faces by exploding and binding/inserting references.* Run the add-in.* Determine the location on the Earth to place your model (based on latitude/longitude - imported, if you wish, from a Google Earth placemark).* Determine the orientation direction for your model (by a second placemark or compass heading).* The add-in generates a KML file, which can be viewed inside of Google Earth.
