from what i read from that macro is it moves everything to 0,0 from a point you pick. it changes the base to 0,0. it zoom extends. then puts everthing on layer 0 with everthing set to by layer. then it sets 0 to current layer. then it purges. but i already went through something like this. now what i want to do is check to see if the base point is actually set to 0,0. then in excel or notepad or something i want to see on paper the name of the file and the base point:
file base point
100-001 0,0,0
100-002 0,0,0
100-003 3/4, 2, 0 (now this i would go change)
i would have to go into the drawing and change that myself because i want a quadrant of a cirlce to be there. i already went through and moved everything as far as i know. but instead of just changing the basepoint to 0,0 in a script, i want to know which ones arnt that way so i can open them and edit them because they need some other things done that a script can do.
but thats for the macro M-dub. maybe im reading it wrong and your giving me all i need already. im sorry if thats the case.[/b]
