Author Topic: importing csv file issues  (Read 4012 times)
whdjr
« on: May 17, 2007, 09:29:49 AM »
I have an excel file with all my layers setup like I want them.  Now I want to make a template file in Autocad that has my layers already setup properly.  What is the best/easiest way to get my layers into Autocad?
My thoughts were to write layers to a csv file from excel, then read that in lisp to make a list for each layer.  Then use 'mapcar' on each layer to creat and set properties.  My problems arise in the csv file.  lisp reads it differently than I thought it would and I'm not sure how to handle it or if there is an easier way.
All thoughts and suggestions are welcome.  :-)
It's Alive!
  • Retired
  • AKA Daniel
Re: importing csv file issues
« Reply #1 on: May 17, 2007, 09:48:51 AM »
I use ADOlisp and access for setting up my layers.
whdjr
« Reply #2 on: May 17, 2007, 10:08:25 AM »
Well I'm using Excel, cause I don't know Access.  I know ADOLISP says it can connect to excel but I don't know any of the commands cuse it seems like they are all sql statements.
« Reply #3 on: May 17, 2007, 10:17:36 AM »
It depends upon your formatting in the CSV file ...
Put each layer information on a seperate line .. i.e.
Name,color,linetype,lineweight,plot style,plottable
thislayer,green,continuous,0.1,PlotStyle1,yes
Then read each line successively
(setq thisline (read-line file))
break down the line according to commas (or whatever your delimiter is) then pass the vars to the layer creation routine.
whdjr
« Reply #4 on: May 17, 2007, 10:20:44 AM »
Yeah that was my thoughts and that is what I was working on doing, I just didn't know if another way existed.
Thanks,
« Reply #5 on: May 17, 2007, 10:40:58 AM »
« Reply #6 on: May 17, 2007, 03:20:20 PM »
whdjr
« Reply #7 on: May 18, 2007, 10:57:36 AM »
