Author Topic: Print Server Name Change?  (Read 16205 times)
SDETERS
« on: February 08, 2010, 04:17:06 PM »
We just changed our Print server so we changed the name of all of our printers.
Now Every drawing our Special group goes into says it can not find the (printername_hgrps_1) and it is going to default to none plot device has been subsituted.  This takes a long time.
Is there a way around this?  Is there a lisp or script that could be run so I can change the printer name when the drawing gets opened.
Thanks Shane
« Last Edit: February 08, 2010, 04:27:54 PM by SDETERS »
Re: Print Server Name Change?
« Reply #1 on: February 08, 2010, 05:54:10 PM »
one might try using page setup overrides when publishing....for the short term
SDETERS
« Reply #2 on: February 08, 2010, 06:02:15 PM »
That is what we are doing.
I did not know if there was an automated way of doing this or not?
Thanks for the feedback
« Reply #3 on: February 08, 2010, 06:22:13 PM »
Sadly' I've been pushed down this this path more than once by some 'others' IT folks renaming both file and print servers at regular random intervals. ;)
I never looked into a programmatic solution like say a LISP, or VBA routine that would read the CTAB Page setup information, and IF it wasn't using your new one would then Import said pagesetup PSETUPIN and set that current on any and all Layout tabs it encountered.
You may want to boost this up to the Code Red folks and see if this nut has already been cracked up there.
dgorsman
« Reply #4 on: February 08, 2010, 06:32:43 PM »
As a work-around for things like this, I have created new page set-ups in a blank file and used TrueView to convert-in-place, to the same version, check the "set default set-up to none", and point to the template file.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #5 on: February 08, 2010, 06:44:11 PM »
or if you wanted a solution while in the Drawing ..
Edit the FileName to suit your template
(defun c:ChangePageSetups (/ old_expert)
    (setq old_expert (getvar "expert"))
    (setvar "expert" 5)
    ;; REVISE TO SUIT
    ;; (VL-CMDF "-psetupin" "PageSetupTemplate_FileName" "pageSetup_Name")
    (vl-cmdf "-psetupin" "c:/PageSetupTemplate.DWG" "*")
    (setvar "expert" old_expert)
SDETERS
« Reply #6 on: February 09, 2010, 08:51:00 AM »
This worked sort of good.
All we have in our pagesetup is *model*
it seems it does not like this so what I did is I went into our template and made a new pagesetup name
now I get the lisp to work now I need to set that new pagesetup name to current.  Like I said I do not know much lisp at all.  Would you please provide a couple extra lines to set my new pagesetup name to current.  Then I think I would be set.  Thanks for all the help and feedback.
« Reply #7 on: February 09, 2010, 09:43:52 AM »
not sure about the setting of a pagesetup current but here is a stripped down version of one that i use in my office.  Ive kept the error handling process in the `PSETUP-IN' routine for you to decide whether to keep or not.
(defun copy_page-setup (DwgName / psetups $acadver$ $typelib$ $classname$ $dbxDoc$)
  (setq $AcadVer$  (atoi (getvar "acadver"))
        $TypeLib$   (findfile "AxDb.dll")
        $ClassName$ (strcat "ObjectDBX.AxDbDocument" "." (itoa $AcadVer$))
        $dbxdoc$   (vla-GetInterfaceObject (vlax-get-acad-object) $ClassName$))
  (setq *acad* (vlax-get-acad-object))
  (setq *active-document* (vla-get-activedocument *acad*))
  (setq psetups (vla-get-plotconfigurations *active-document*))
  (vla-open $dbxdoc$ DwgName)
  (vlax-for x
            (setq dbxdoc-collection (vla-get-plotconfigurations $dbxdoc$))
            (setq name (vla-get-name x))
            (vla-copyobjects
              $dbxdoc$
              (vlax-safearray-fill
                (vlax-make-safearray vlax-vbobject '(0 . 0))
                (list (vla-item dbxdoc-collection name)))
              psetups ))
  (vlax-release-object $dbxdoc$)
;; BEGIN MAIN
(defun c:psetup-in ( / *error* ERROR-LST-)
  ;; BEGIN SETUP
       (setq
         ERROR-LST-
                    '("AUTOSNAP" "OSMODE" "APERTURE" "HPSPACE" "HPASSOC"
                      "MIRRTEXT" "AUPREC" "LUPREC" "DIMZIN" "CECOLOR" "CLAYER")
         ERROR-LST- (mapcar (function (lambda (a) (list 'setvar a (getvar a)))) ERROR-LST-)
       );_end setq
       (defun *error* (msg)
          (command) (command)
          (mapcar 'eval ERROR-LST-)
  ;; END SETUP
  ;; BEGIN CODE
   (setq *acad-object* (vlax-get-acad-object))
   (setq *active-document* (vla-get-activedocument *acad-object*))
   ;; delete existing pagesetups
   (vlax-map-collection (vla-get-plotconfigurations *active-document*) 'vla-delete)
   ;; import the new ones
   (copy_page-setup "C:\\tmp\\Test-PageSetups-ABS08.dwt")
  ;; END CODE
  ;; BEGIN CLEANUP
  (*error* "")
  ;; END CLEANUP
SDETERS
« Reply #8 on: February 09, 2010, 10:34:11 AM »
Sorry I get an error saying "error: malformed list on input"  When I try to run this program.
I modified the code for my appropriate dwt file.
Is there anything else I need to add to it?  Sorry for being a pain in the a--.
« Reply #9 on: February 09, 2010, 11:41:02 AM »
no that just means that i dont have a parentheses or something (I messed up when i was deleting stuff). let me fix it.
« Reply #10 on: February 09, 2010, 11:43:48 AM »
*hummm* nope it seems okay. Are you sure you copied it correctly? I would copy and paste one more time to be sure.
SDETERS
« Reply #11 on: February 09, 2010, 11:56:27 AM »
Yep I got it now.  I was the one who messed up copying and pasting.
I Still have the problem with the page setup manager wanting to use *model*.   Please see JPEG file.
 In my DWT file I have this set as for example *model* (ME) set to current.
It got the ME name but it did not set that name to current.
« Reply #12 on: February 09, 2010, 03:55:53 PM »
I stated that i didnt know of a way to set the page setup; they are just a collection of settings. However, you can manually set the plotting STUFF...
-e.g. Here is how to set the pc3 file or plotter used.
(vla-put-configname
  (vla-get-layout
    (vla-get-PaperSpace
      (vla-get-ActiveDocument
(vlax-get-object "AutoCAD.Application")
  "Ghostscript.pc3"
;; or
(vla-put-configname
  (vla-get-layout
    (vla-get-PaperSpace
  "None"
SDETERS
« Reply #13 on: February 09, 2010, 04:03:40 PM »
oh OK Sorry I get lost sometimes in the lisp programs.  I do not know how you come up with all of the calls and code and parentheses and such.  I really do appreciate your help.
Thanks again  Off to look at your other suggestion.
« Reply #14 on: February 09, 2010, 05:32:20 PM »
Try this one:
(vla-put-configname
  (vla-get-layout
    (vla-get-PaperSpace
  "Ghostscript.pc3"
