Code Red => .NET => Topic started by: Coder on February 17, 2016, 01:46:50 AM
Hello guys.
It seems that I can't make an instance of SaveFileDialog ! and it requires to feed it with the arguments as in the attached image.
Is there any work around this error?
Thanks a lot.
edit:kdub->fixed post title
The SaveFileDialog constructor does not take parameters.
New the SaveFileDialog () then set properties.
https://msdn.microsoft.com/en-us/library/system.windows.forms.savefiledialog(v=vs.110).aspx
Yes,
I wonder why it gives me that error message this time !
Silly me , I assumed you meant the System.Windows.Forms.SaveFileDialog()
Did you mean Autodesk.AutoCAD.Windows.SaveFileDialog
I should have guessed that.
Provide more detail about what doesn't work for you .
edit:fixed post title
See if these help
http://through-the-interface.typepad.com/through_the_interface/2009/08/allowing-a-user-to-select-from-multiple-file-formats-inside-autocad-using-net.html
http://through-the-interface.typepad.com/through_the_interface/2007/08/using-autocads-.html
http://through-the-interface.typepad.com/through_the_interface/2007/03/replacing_the_o.html
Not silly at all but that is the truth :wink:
I confused between the two SvaeFileDialog methods, Windows and AutoCAD. sorry for that.
I added the full path of the NameSpace System.Windows.Forms.SaveFileDialog svd ..... and that 's what I was after.
Many thanks Kerry for your prompt help.
And thanks for the links , they look great and very informative.
(http://www.theswamp.org/screens/mp/thumbsup.gif)
