Author Topic: Raster Design Remove Grid  (Read 1804 times)
therock003
« on: March 24, 2009, 03:33:13 PM »
I have some scanned Maps on raster format and i need to find the way to remove the grid from theraster image. How can i do this with a few clicks?  :|
M-dub
Re: Raster Design Remove Grid
« Reply #1 on: March 24, 2009, 03:46:13 PM »
IDELSMART might help you a bit, but a few clicks?  Good luck!  :)
Edit:  I just tried it and found that they've improved the functionality of it since I last tried it.  (2004)
« Reply #2 on: March 24, 2009, 03:56:03 PM »
what grid?
and what is the file format of your raster map image?
therock003
« Reply #3 on: March 24, 2009, 04:10:53 PM »
what grid?
The Coordinate Grid. The file is a .tiff file and it is georeferenced. Basically i need to vectorize it, but the grid makes it difficult, cause polyline follwer follws the grid when it intersects with other geomtric properties.
« Reply #4 on: March 25, 2009, 11:51:35 AM »
what grid?
you will need to do a better job of guiding Raster Design.
Or use an image editing application to select those grid line pixels and somehow neutralize them.
Or, why not get a DEM or other for your area, and build your surface contours from that?
The data you are after may be available in other formats....
