Author Topic: Duplicate Objects Display Thickens  (Read 1465 times)
Rob...
« on: April 25, 2016, 06:47:51 AM »
The more objects the thicker the display. I think it is new to 2016.
I have not been able to find much more than verification that this is a new feature. Help is no help.
Does anyone know what this is called and if there is a variable for it?
CAD Tech
rkmcswain
Re: Duplicate Objects Display Thickens
« Reply #1 on: April 25, 2016, 07:30:16 AM »
See this thread.
Not sure if this was intentional or a goof....
Rob...
« Reply #2 on: April 25, 2016, 07:39:21 AM »
I saw that thread before. It unfortunately does not have a solution for turning off the thickening directly, only that switching the view style does have an effect. It's only a work around.
CAD Tech
huiz
  • Certified Prof C3D
« Reply #3 on: April 25, 2016, 08:27:33 AM »
I assume it is a side effect of the line smoothing since 2016. Because softer pixels are shown along the lines to create a smoother effect, you probably see where multiple lines are over eachother.
If you turn off line smoothing, you also see overlapping lines as thicker lines, but much uglier.
Rob...
« Reply #4 on: April 26, 2016, 06:47:35 AM »
As far as I can determine, it has to do with obscured edges but there is no way to turn it off in 2D wireframe.
CAD Tech
