Author Topic: (AutoCAD LT) Change Dims from 3' to 36"?  (Read 7822 times)
craigr
« on: March 12, 2008, 02:45:59 PM »
In LT 2008, how do you change Dims from 3' to 36"?
In the Dim Style Manager under the 'Primary Units' tab, I have gone thru the options and can't find it. I have the Unit format as Architectural right now and the Dim shows up as 3'.
I don't use Dims much so I always stumble thru them every time I use them.
craigr
deegeecees
Re: Change Dims from 3' to 36"?
« Reply #1 on: March 12, 2008, 02:48:59 PM »
You could change the primary units to Decimal, but you won't get the inch marks (")
Or, change primary units to Fractional, and use a (") as a suffix, AFAIK.
craigr
« Reply #2 on: March 12, 2008, 02:49:54 PM »
I found that, but I would think there HAS to be a way to just show inches.
craigr
Josh Nieman
« Reply #3 on: March 12, 2008, 02:50:14 PM »
You'd actually have to set your UNITS to be INCHES - Fractional or Decimal... in the Primary Units tab of the Dim Style... that's assuming it's the same as regular ACAD... I never heard anything about the dimension styles being different from LT to vanilla... but YMMV
If you don't get the " mark.... add the " to the "suffix" in the dim style.
Kate M
« Reply #4 on: March 12, 2008, 02:51:24 PM »
Nope, they're exactly the same.
architecture68-raff
  • Strange things are afoot at the Circle-K.
« Reply #5 on: March 12, 2008, 02:56:20 PM »
How many dimensions do you have to put in this format?
If nothing else, you could always override the dimension if it is a onsie twosie kind of thing.  I realize its not optimal..... :|
Chicago, Illinois
ADT 2005, Revit Architecture 2009, Sketchup 7
craigr
« Reply #6 on: March 12, 2008, 03:11:24 PM »
LT2008 doesn't have 'inches' as an option under 'Unit format'.
The options are:
Scientific
Decimal
Engineering
Architectural
Fractional
Windows Desktop
Or, am I looking in the wrong place?
craigr
Josh Nieman
« Reply #7 on: March 12, 2008, 03:15:51 PM »
I'm sorry, I was going by memory... it would be Fractional or Decimal.  I got a little mixed up.
craigr
« Reply #8 on: March 12, 2008, 03:17:10 PM »
Nope. Doesn't do it. That is what I have it set at and it shows 3'.
Looks like I may be SOL.
Thanks anyway,
craigr
Josh Nieman
« Reply #9 on: March 12, 2008, 03:17:30 PM »
Just don't remember to add the Inch Tick mark to the "Suffix" there.
Remember: Autocad doesn't have a clue what you're drawing... inches, meters, miles, light years, parsecs, fathoms, or butt cracks... you have to tell it what it is... you just draw them so-many-units in length... the label is just superficial.
David Hall
  • Automatic Duh Generator
« Reply #10 on: March 12, 2008, 03:17:52 PM »
I would set Primary units to decimal, suppress/set precision to 0 decimal places, and add " to suffix (unless you want to see decimal pieces of an inch i.e. 36.34" instead of 36")
Josh Nieman
« Reply #11 on: March 12, 2008, 03:18:20 PM »
Thanks anyway,
craigr
Are you drawing 1 units = 1 foot, or 1 unit = 1 inch?
David Hall
« Reply #12 on: March 12, 2008, 03:19:35 PM »
Your not SOL, just need to get the settings correct
craigr
« Reply #13 on: March 12, 2008, 03:20:04 PM »
Are you drawing 1 units = 1 foot, or 1 unit = 1 inch? -
I'm not sure what you mean, but I found a fix.
'Text override' in the Properties box.
craigr
David Hall
« Reply #14 on: March 12, 2008, 03:21:14 PM »
Whilst that does work, you will have to override every dim to fix the problem.  You should figure out how to set the style so all dims work correctly
