Hi Tim,
I'm missing something from a batch processing lisp routine you posted before.
I seem to keep breaking the thing :ugly:
;; To Batch Drawings As ZBase XREF's ......
;; Note: replace the Path/filename below to call up your Lisp
;; to process the drawings the way you want.
;; Make sure your lisp program is in a 'support' folder ..
;; Setup to batch specific project drawing files and prevent any non illiterate from destroying a project
(autoload "mkxref" '("mkxref"))
(setq my_lisp_file "mkxref.lsp"); Place your specific lisp here !
;; Load Supporting Functions
;; Old Version of 'BrowseForFolder' by: Tony Tanzillo
(defun BrowseForFolder ( Message / sh folder parentfolder folderobject result)
(setq sh
(vla-getInterfaceObject
(vlax-get-acad-object)
"Shell.Application"
(setq folder
(vlax-invoke-method
sh
'BrowseForFolder
0
Message
0
(vlax-release-object sh)
(if folder
(setq parentfolder
(vlax-get-property folder 'ParentFolder)
(setq FolderObject
(vlax-invoke-method
ParentFolder
'ParseName
(vlax-get-property Folder 'Title)
(setq result
(vlax-get-property FolderObject 'Path)
(mapcar 'vlax-release-object
(list folder parentfolder folderobject)
(if (/= (substr result (strlen result)) "\\")
(setq result (strcat result "\\"))
result
); defun
(defun C:MAKEXREF ()
;; portions by Tim Willey
(if (setq DirPath (BrowseForFolder "Select directory to batch drawings."))
(setq DwgList (vl-directory-files DirPath "*.dwg" 1))
(setq ScrFile (strcat DirPath "batchme.scr"))
;(setq Ofil (open ScrFile "W"))
(setq Ofil (open ScrFile "R"))
(write-line "SDI 0" Ofil); Force Multi-Document mode
(write-line (strcat "(setvar " (chr 34) "FILEDIA" (chr 34) " 0)") Ofil)
;; Check for specific project drawing names starting with "Z0001"..
;; Edit this line for your specific batch
(foreach Dwg DwgList
;;(if (= (substr Dwg 1 5) "P0604")
(setq FullPath (strcat DirPath Dwg))
(write-line (strcat "_.open " (chr 34) FullPath (chr 34)) Ofil)
(write-line (strcat "(load " (chr 34) my_lisp_file (chr 34) ")") Ofil)
(write-line (strcat "(setvar " (chr 34) "FILEDIA" (chr 34) " 1)") Ofil)
(write-line "_.qsave" Ofil)
(write-line "_.close" Ofil)
); progn
;;); if
); foreach
(close Ofil)
(command "_.script" ScrFile)
); progn
); if
); function
(prompt "\nType MAKEXREF to begin the batch process:")
