using System;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly
: CommandClass
(typeof(BlockAttributeSample
.Commands))]
namespace BlockAttributeSample
public class Commands
// test command
[CommandMethod("Test")]
public void Test()
var doc = AcAp.DocumentManager.MdiActiveDocument;
var db = doc.Database;
var ed = doc.Editor;
using (var tr = db.TransactionManager.StartTransaction())
foreach (var br in db.GetBlockReferences("stamp"))
var owner = br.OwnerId.GetObject<BlockTableRecord>();
if (owner.IsLayout)
ed.WriteMessage("\n" + owner.LayoutId.GetObject<Layout>().LayoutName);
else
ed.WriteMessage("\n" + owner.Name);
foreach (var att in br.GetAttributes())
ed.WriteMessage($"\n\t{att.Tag}: {att.TextString}");
tr.Commit();
// extension methods
static class extension
// returns the object (opened in the specified mode)
public static T GetObject<T>(
this ObjectId id,
OpenMode mode = OpenMode.ForRead,
bool openErased = false,
bool forceOpenOnLockedLayer = false) where T : DBObject
if (id == ObjectId.Null)
throw new ArgumentNullException
(nameof
(id
var tr = id.Database.TransactionManager.TopTransaction;
if (tr == null)
throw new Autodesk
.AutoCAD.Runtime.Exception(ErrorStatus
.NoActiveTransactions);
return (T)tr.GetObject(id, mode, openErased, forceOpenOnLockedLayer);
// gets all references of the block (opened for read)
public static IEnumerable<BlockReference> GetBlockReferences(this Database db, string blockName)
if (db == null)
(nameof
(db
var tr = db.TransactionManager.TopTransaction;
if (tr == null)
throw new Autodesk
var bt = db.BlockTableId.GetObject< BlockTable>();
if (bt.Has(blockName))
var btr = bt[blockName].GetObject<BlockTableRecord>();
foreach (ObjectId id in btr.GetBlockReferenceIds(true, false))
yield return id.GetObject<BlockReference>();
if (btr.IsDynamicBlock)
foreach (ObjectId btrId in btr.GetAnonymousBlockIds())
var anonBtr = btrId.GetObject<BlockTableRecord>();
foreach (ObjectId id in anonBtr.GetBlockReferenceIds(true, false))
// gets the attribute references (opened for read)
public static IEnumerable<AttributeReference> GetAttributes(this BlockReference source)
if (source == null)
(nameof
(source
var tr = source.Database.TransactionManager.TopTransaction;
if (tr == null)
throw new Autodesk
foreach (ObjectId id in source.AttributeCollection)
yield return id.GetObject< AttributeReference>();
