Author Topic: best practice when using dialog result OK  (Read 6139 times)
Ken Alexander
Re: best practice when using dialog result OK
« Reply #15 on: April 23, 2010, 11:36:56 AM »
Oh, and as another point, you're using a MessageBox in the inner "catch" statement.  That's OK, but it forces the user to hit OK to continue.  Imagine what would happen if the user selected 100 files, and they all start erroring out - the user might have to hit "OK" 100 times before the routine finally exits.
Another point to go along with this is allowing the user to cancel out of the copy.  Depending on the number and size of files, this could take a while.  You might look at copying files/directories using My.Computer.FileSystem namespace.  My.Computer.FileSystem.CopyFile gives options for this.
Ken Alexander
« Reply #16 on: April 23, 2010, 11:38:43 AM »
Don't worry about multiple exit points in .NET... it's got one of them managed stacks  :roll:
Glenn R
« Reply #17 on: April 23, 2010, 11:48:36 AM »
You could also use Path.Combine(string1, string2) as well...
David Hall
  • Automatic Duh Generator
« Reply #18 on: April 23, 2010, 11:54:24 AM »
Thanks eveyone, I will look into the Path options
Bobby C. Jones
« Reply #19 on: April 23, 2010, 01:27:19 PM »
I recommend using it with wanton abandon :-)
Me too.  But I'm also a huge fan of jump statements.  I do this all the time.
   static void Main(string[] args)
      int i = 0;
      loop_begin:
        if (i == 10)
          goto exit;
        Console.WriteLine(i++);
      goto loop_begin;
      exit:
      Console.ReadKey();
Bobby C. Jones
David Hall
« Reply #20 on: April 23, 2010, 04:21:52 PM »
 :lmao: :lmao: :lmao:
