Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
I'd like to change the default value of this lisp.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: I'd like to change the default value of this lisp. (Read 1815 times)
asami486
Guest
on:
January 21, 2017, 12:25:58 AM »
I'd like to change this lisp.
(Thank you VVA. eco 1.1)
Its default value is "No" (when I just push the SPACE KEY).
But I wanna change the value to "Yes"
(then it'll remove the objects except a boundary created by the lisp)
Logged
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
class keyThumper<T>:ILazy<T>
Re: I'd like to change the default value of this lisp.
Reply #1 on:
January 21, 2017, 01:27:34 AM »
Try something like this :
Firstly, you need to understand that hitting ENTER or SPACEBAR on a getkword does not return any of the options
... it actually returns NIL
Code - Auto/Visual Lisp:
[Select]
initget
"Yes No"
setq
result
getkword
\n
Delete objects? [Yes/No] <Yes> : "
SPACE
or
RETURN
nil
y
or
Y
"Yes"
n
or
N
"No"
apples
Invalid option keyword ... try again
Then you need to write some code to catch the nil result, or a correct one
[Select]
initget
"Yes No"
setq
keyword
getkword
\n
if
or
not
keyword
keyword
"Yes"
alert
"Proceed to delete"
Once you are sure of your code replace the existing in the source :
[Select]
if
pl
progn
initget
"Yes No"
setq
keyword
getkword
\n
if
or
not
keyword
keyword
"Yes"
mapcar
lambda
x
if
vlax-write-enabled-p
x
vla-erase
x
obj
;; else
princ
\n
It was not possible to construct a contour"
;_ end of if
Logged
Called Kerry in my other life
I live at UTC + 13.00
Grrr1337
Swamp Rat
WWW
Reply #2 on:
January 21, 2017, 03:47:10 PM »
Check Lee Mac's tutorial about
prompting with default option
This is always a huge help when using
getkword
Logged
(apply ''((a b c)(a b c))
vevo.bg
Administrator
Seagull
Reply #3 on:
January 23, 2017, 09:03:02 AM »
Check out my version of the "RRB Default Method" (`my version' is just a very small improvement I did while standing on RRB's shoulders).
https://www.theswamp.org/index.php?topic=39042.msg442290#msg442290
Logged
TheSwamp.org
(serving the CAD community since 2003)
Global Moderator
Seagull
Reply #4 on:
January 25, 2017, 07:52:09 AM »
More fun.
----------- keyword examples -------------
http://www.theswamp.org/index.php?topic=15173.0
http://www.theswamp.org/index.php?topic=6992.0
http://www.theswamp.org/index.php?topic=6992.msg93574#msg93574
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
