Author Topic: Coordinates and from the list  (Read 2939 times)
FELIX
Re: Coordinates and from the list
« Reply #15 on: December 22, 2016, 12:31:17 PM »
MP, I forgot to thank you anyway. :smitten:
OK.
« Reply #16 on: December 22, 2016, 12:33:46 PM »
You're most welcome Felix.
« Reply #17 on: December 22, 2016, 01:32:11 PM »
So many cats, so little skinnin' time ...
I want to play too!  :lol:
(defun foo ( ent )
    (   (lambda ( bar lst )
            (bar lst (list (cdr (assoc 038 lst))) (cdr (assoc 210 lst)))
        (lambda ( lst elv vec / itm )
            (if (setq itm (assoc 10 lst))
                (cons (trans (append (cdr itm) elv) vec 0) (bar (cdr (member itm lst)) elv vec))
        (entget ent)
FELIX
« Reply #18 on: December 22, 2016, 03:05:50 PM »
Lee Mac, excellent, very good, I like your programming logic, it's a bit similar to mine. I am old because after 43 years programming (43 is not my age) it is difficult to fit the most current logics.
MP, your logic is advanced for me but also good, I said that I did not enjoy joking to see your reaction that was good, congratulations.
To all of the Forum that are visiting this topic the games are only valid when they stimulate the best perfomance that programming or is a healthy play.
OK.
« Reply #19 on: December 22, 2016, 03:37:45 PM »
Well if it's any consolation I'm currently 00111010.
I was born the same year LISP implementation began at MIT.
Humorously, my age and the year mentioned above share digits.
re: my reaction: you caught me on a good day, lol.
LISP puzzles draw many of us here.
Great fun and pun intended.
roy_043
  • BricsCAD 18
« Reply #20 on: December 22, 2016, 05:11:56 PM »
Another:
(defun UsingCurveFunctions (obj / i ret) ; Obj as vla-object or ename.
  (repeat (setq i (+ (vlax-curve-getendparam obj) (if (vlax-curve-isclosed obj) 0 1)))
    (setq ret (cons (trans (vlax-curve-getpointatparam obj (setq i (1- i))) 0 1) ret))
FELIX
« Reply #21 on: December 23, 2016, 12:32:09 PM »
MP, we are the same age.
Roy_043 very good.
To all of the Forum a Merry Christmas.
OK.
