While looking at some schematics and one line electrical drawings it occurred to me that a one click
command to drag / stretch a poly line segment might be a good thing. Does that ability exist in any
Autocad versions? Would anyone be interested in such a routine?
Looks like the wiring drawings keep the poly line segments parallel to the X or Y axis and if you want to
stretch a segment it's easy enough to use the stretch command but I though it might be an interesting lisp.
Pick the segment and use that point (on the pline) to stretch from.
Move the pointer to the new location, pline stretches with the pointer in real time.
Click to pick new location.
As long as the adjacent segments are perpendicular to the segment to be moved and parallel to an axis
the solution is easy. If the adjacent is parallel to the segment to be moved, create a new vertex and
stretch the new segment.
Radius plines would be dealt with in a later version.
Just thought I would toss the idea out there.
