Author Topic: "Overkill" command is not working  (Read 7142 times)
PHX cadie
« on: October 23, 2006, 06:44:32 PM »
.....I get:
12 duplicate(s) deleted.
6 object(s) deleted.
Invalid option keyword.
It worked last month or so?
What does Invalid Option keyword mean?  fixes? All I do is type overkill or from the pulldown and window the area, crossing or other makes no dif.
 :realmad:
Acad 2013 and XM
Re: "Overkill" command is not working
« Reply #1 on: October 23, 2006, 07:16:03 PM »
Perhaps if you posted  test DWG so we can recreate the error.
What version of express tools are you using?
PHX cadie
« Reply #2 on: October 23, 2006, 07:26:53 PM »
The first ? in the FAQ was about support for ET 05, so I assume its 05
attached the current dwg, 05
Just tried an audit, though with 15 errors, overkill did not work.
Thank You
« Last Edit: October 23, 2006, 07:33:28 PM by PHX cadie »
Acad 2013 and XM
« Reply #3 on: October 23, 2006, 08:42:29 PM »
Here are my test results.
No error though.
I don't have 2005
ACAD2004
Command: overkill
Initializing...
Select objects: Specify opposite corner: 720 found
Select objects:
23 duplicate(s) deleted.
25 object(s) deleted.
Command: '_zoom
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window] <real time>: _e
Command:
Command:
Command: _audit
Fix any errors detected? [Yes/No] <N>: y
Auditing Header
 DXF Name   Current Value        Validation              Default
AcDbSortentsTable(E2)
    Error for Entry (1B1BD,1B21E) eDuplicateKey         fixed
    Error for Entry (1B2F3,1B285) eDuplicateKey         fixed
    Error for Entry (1B314,1B3BA) eDuplicateKey         fixed
 22      Blocks audited
Pass 1 679     objects audited
Pass 2 679     objects audited
Pass 3 1900    objects audited
Total errors found 3 fixed 3
ACAD2006
Command: overkill
Initializing...
Select objects:
24 duplicate(s) deleted.
24 object(s) deleted.
Command:
Command:
Command: _audit
Auditing Header
    Error for Entry (1B1B9,1B1BB) eDuplicateKey         fixed
    Error for Entry (1B200,1B1FF) eDuplicateKey         fixed
    Error for Entry (1B243,1B241) eDuplicateKey         fixed
    Error for Entry (1B2EB,1B2C7) eDuplicateKey         fixed
    Error for Entry (1B307,1B308) eDuplicateKey         fixed
    Error for Entry (1BC5E,1BC5F) eDuplicateKey         fixed
 22      Blocks audited
Total errors found 6 fixed 6
PHX cadie
« Reply #4 on: October 23, 2006, 11:10:37 PM »
Looks as though you did not get the "invalid option keyword" w/ 04 or 06.
That's odd, perhaps tomorrow I should try overkill on a different dwg.
I certainly appreciate your help and time.
Thank You CAB!
Acad 2013 and XM
« Reply #5 on: October 24, 2006, 08:02:52 AM »
Any time.
Do let us know what you find.
Kate M
« Reply #6 on: October 24, 2006, 01:47:24 PM »
Try telling it to ignore polylines. That has fixed that error for me...although if you're trying to modify polylines... :-)
PHX cadie
« Reply #7 on: October 24, 2006, 02:06:10 PM »
Ignoring PL's worked, Thank You.
Some wierd things about that dwg, 2 hatches next to/on top of each other, allot of dup lines. 1st audit had 103 fixes, closed, saved, 2nd audit found/fixed 12. I don't know.
Overkill worked on a new dwg, but not when the first was copied into it. Something wrong w/ that file.
Thanks All !
Acad 2013 and XM
