Author Topic: Code Display in Browser  (Read 6030 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: Code Display in Browser
« Reply #15 on: June 09, 2023, 09:53:49 PM »
looks great!
have you seen this? https://gist.github.com/
Yes, that's my code.
. . . or did you mean the editor display ??
Called Kerry in my other life
I live at UTC + 13.00
It's Alive!
  • Retired
  • AKA Daniel
« Reply #16 on: June 09, 2023, 10:44:39 PM »
all care, no responsibility
Livingstone v Roskilly [1992]
What's this project? you're writing all the HTML stuff too?
kdub_nz
  • SuperMod
« Reply #17 on: June 10, 2023, 12:06:42 AM »
Hi Dan,
Yes, I've coded all the HTML, CSS, JS jQuery for the project.
It's really just a confirmation for myself that the coding I've learnt has stuck in the wet gray stuff.
The project will be a (sort-of) library/cookbook of some of the stuff I've used over time.
It's a hobby project I s'pose but I see it as useful.
I think I'll spend a couple days evaluating prism.js and highlight.js for generating the syntax highlighting.
This will remove the current reliance on 'CopyToHtml' from Visual Studio. The goal is to be able to use plain text input code and display in an acceptable manner.
I think I'll be able to use them to generate the drop-in <pre> <code> ... </code> </pre> which will save a lot of bandwidth when viewing the page. Basically the pages will be static.
I think I can modify the config files to get the result I'll want.
This will allow me to post a variety of languages without too much dev overhead.
I've had a site for 8+ years and hardly used it , except for playing/learning when the mood took me.
I can't imagine this will be income generating but I may get a few coffee donations from it down the road.
I probably should have done this a few years ago :)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #18 on: June 10, 2023, 04:49:33 AM »
Can’t wait to see it.
Through the interface is kind of hard to read, the width is way too narrow, I think around 100 chars’ width might be a good balance
https://drive-cad-with-code.blogspot.com/ Norman’s is very readable, bigger bolder font
https://gilecad.azurewebsites.net/UserInterfaces.aspx  Gile’s is easy on the eyes, and scrollable
http://www.lee-mac.com/programs.html Lee’s is amazing, a page with the description overview, HTML view in dark, light and vlide, the formatting is juicy and delicious
kdub_nz
  • SuperMod
« Reply #19 on: June 14, 2023, 10:50:49 PM »
Traslation from C# to HTML using prism.js.
Just need to learn how to write a plug-in for extendables to handle the AutoCAD classes and methods ( or not ! )
font-size is 20px, perhaps adequate
Atook
  • AKA Tim
« Reply #20 on: June 15, 2023, 09:59:51 AM »
Looks good!
kdub_nz
  • SuperMod
« Reply #21 on: June 24, 2023, 02:54:01 AM »
Been playing with menu options.
I think this may be the winner . . . . or some variation of it :)
Fashioning this stuff from scratch is cathartic, and fun.
« Last Edit: June 24, 2023, 02:58:36 AM by kdub_nz »
kdub_nz
  • SuperMod
« Reply #22 on: June 24, 2023, 03:14:16 AM »
Though, this may be better :
a more vibrant color and increased size for the selected topic . . . may be different tomorrow.
kdub_nz
  • SuperMod
« Reply #23 on: June 24, 2023, 11:54:33 PM »
That's it for today !
It's Alive!
  • Retired
  • AKA Daniel
« Reply #24 on: June 25, 2023, 01:02:30 AM »
Nice!
Are you going to write something for every class?... because there’s a lot of them
kdub_nz
  • SuperMod
« Reply #25 on: June 25, 2023, 01:59:59 AM »
Nice!
Yes, there is a lot.
Quite a bit of it uses similar methodology to access and modify so we wouldn't need unique code for each. I thought some could be done on a recipe basis . . . 'this applies to xxx and . . etc. So several of the links from the Model diagram could point to the same info page.
I had imagined a bit of a cookbook, rather than a full blown duplication/re-arrangement of the docs.
 . . and also having links to the official docs
But really, it's not as if I don't have some spare time. :)
and besides, I could (or hope to ) learn something new along the way if I pay attention.
Atook
  • AKA Tim
« Reply #26 on: June 25, 2023, 09:24:09 AM »
Looks like a good project for learning! You going to post it live somewhere?
kdub_nz
  • SuperMod
« Reply #27 on: June 25, 2023, 03:51:11 PM »
Hi Tim,
Yes, it's sure been a good learning project.
I've been down a few rabbit holes. I'm trying to do a bit each day, as time allows.
I will upload it to a live site, in stages I think.
This is my first full project of this type, so I'm hoping it turns out like I envision.
kdub_nz
  • SuperMod
« Reply #28 on: June 27, 2023, 03:18:49 AM »
Git saved my arse again today . . . . . dragged be out of a big rabbit hole :)
« Reply #29 on: June 27, 2023, 09:50:36 AM »
Oh I know that feeling (feels good and odd at the same time)! "Yippie-dippy! it runs again! ...but I just lost a lot of work; I wonder if I just changed X it would have worked?"
