CAD Forums => CAD General => Topic started by: SDETERS on July 29, 2004, 02:30:20 PM
What I need to do is make some text that is made up of closed lines so I can extrude it into a solid.
Any thoughts would be of some great help.
Shane Deters
Designer
I believe you could do this by using some outline font, then use Express Tools > Explode Text.
Just an idea
Just an idea
That's the way I would do it, as well, M-dub.
I have found the best fonts to explode, region and extrude are true type....
What if I do not have the EXpress tools? I am on Autocad 2004? They must not be loaded on my machine.
Thanks For the info
If you upgraded from 2000+ they should have been "migrated" with the upgrade.....jump in the middle of your IT.......
If you have 2004, load the CD once again and look for the express tools. They are on the cd.
