Author Topic: (Challenge) Time travel  (Read 5446 times)
« on: March 02, 2005, 10:45:46 AM »
Write a program that returns the time traveled in the speed of light and the speed of sound given a distance in either miles or kilometers.
Pseudo code:
Enter distance (e.g. 100m or 100k):
- or -
Enter distance:
Is that [Miles Kilometers]:
distance / speed of light
distance / speed of sound
output
travel time at light =
travel time at sound =
nivuahc
« Reply #1 on: March 02, 2005, 11:39:22 AM »
(defun c:speed ( / )
  (setq user_distance (getreal "\nDistance to travel, in miles: "))
  (princ (strcat "\nTravel time at light speed = " (rtos (/ user_distance 299792458.0) 2 9) " seconds"))
  (princ (strcat "\nTravel time at speed of sound = " (rtos (/ user_distance 340.29) 2 9) " seconds"))
nivuahc
« Reply #2 on: March 02, 2005, 11:57:59 AM »
(defun c:speed ( / measurement_key user_distance)
  (setq measurement_key (strcase (getstring "\nWould you like to calculate for [M]iles or [K]ilometers? ")))
  (setq user_distance (getreal "\nDistance to travel: "))
    ((= measurement_key "M")
     (princ))
    ((= measurement_key "K")
          (princ (strcat "\nTravel time at light speed = " (rtos (/ (* user_distance 0.62) 299792458.0) 2 9) " seconds"))
     (princ (strcat "\nTravel time at speed of sound = " (rtos (/ (* user_distance 0.62) 340.29) 2 9) " seconds"))
     (princ))
    ((t (princ "\nInvalid distance type. Select M or K at the prompt!") (c:speed)))
;; 1km = 0.62m
;; speed of light = 299792458.0 miles per second
;; speed of sound = 340.29 miles per second
« Reply #3 on: March 02, 2005, 12:05:42 PM »
I do believe that's the speed of light in meters per second.
nivuahc
« Reply #4 on: March 02, 2005, 12:07:06 PM »
:oops: oops!
nivuahc
« Reply #5 on: March 02, 2005, 12:17:06 PM »
Okay, my math is wrong, obviously, and I should check for the M or K before I ask for the distance.
That should be enough, however, for someone to either massacre or build on.  :moon:
Waddaya 'spect for a quickie?  :twisted:
« Reply #6 on: March 02, 2005, 12:37:02 PM »
So i dont get it.
If i traveled 1hr and 120 miles how long would it have taken light and sound to travel that same distance?!  *Phew* Im lost.
nivuahc
« Reply #7 on: March 02, 2005, 12:39:40 PM »
The way I understood it is that
1. You have a distance to travel
2. How fast could you get there if you travelled at the speed of light?
3. How fast could you get there if you travelled at the speed of sound?
I might have misunderstood, of course (I mean, I assumed the m meant miles for goodness sake!).
« Reply #8 on: March 02, 2005, 01:29:01 PM »
Quote from: nivuahc
you are correct.
for example to travel 100 miles at the speed of light it would take you 0.0005 seconds, approximately.
« Reply #9 on: March 02, 2005, 02:09:22 PM »
Light travels approximately one foot in a nano second; I always enjoyed that factoid.
Birdy
« Reply #10 on: March 02, 2005, 02:41:12 PM »
:blink:
Slow day, eh?
You guys are to much.
c=3.0X10^8 meters/second (if I remember correctly)
aprox 186,000 miles/second
Sound varies, proportional to the density of the media. (=0 in space...
that's why "in space, nobody can hear you scream.")
aprox. 750 miles/hour in "dry" air at sea level.
FWIW
« Reply #11 on: March 02, 2005, 02:47:10 PM »
In addition to what Birdy said. For calculating the speed of sound you can use 1135.07947 feet per second or 774.98 miles per hour. That's in dry air at 75°f.
Source:http://hyperphysics.phy-astr.gsu.edu/hbase/sound/souspe.html
Birdy
« Reply #12 on: March 02, 2005, 03:38:17 PM »
meh. I forgot it's also temperature dependent.
been quite awhile.
« Reply #13 on: March 02, 2005, 04:37:42 PM »
Here is my spin off of Nivuahc first post:
(defun c:speed ( / u-lunits ltspd sndspd user_distance)
(setq u-lunits (getvar 'lunits))
(setvar 'lunits 2)
(if (not *defaultFILTER*)
  (setq *defaultFILTER* "Miles")
(initget 0 "Miles Kilometers")
(setq P
((getkword
   (strcat
     "\n Calculate distance in (K)ilometers or (M)iles? <Hit Enter for "
     *defaultFILTER*
(*defaultFILTER*)
(setq *defaultFILTER* P)
(cond ((= P "Miles")
       (setq prmpt "miles"
    ltspd  670616640
    sndspd 774.98
      ((= P "Kilometers")
       (setq prmpt "kilometers"
    ltspd  1079252865.88416
    sndspd 1247.209413
(setq user_distance (getdist (strcat "\nPick or enter distance to travel in " prmpt " :")))
  (alert
  (strcat
"\nTime to travel " (rtos user_distance) " " prmpt " at the speed of light = "
"\n"  (rtos (* (/ user_distance ltspd) 3600) 2 11) " seconds"
"\n" (rtos (* (/ user_distance ltspd) 60) 2 11) " minutes"
"\n" (rtos (/ user_distance ltspd) 2 11) " hours"
"\n" (rtos (/ (/ user_distance ltspd) 24) 2 11) " days"
"\n"
"\nTime to travel " (rtos user_distance) " " prmpt " at the speed of sound = "
"\n"  (rtos (* (/ user_distance sndspd) 3600) 2 5) " seconds"
"\n" (rtos (* (/ user_distance sndspd) 60) 2 5) " minutes"
"\n" (rtos (/ user_distance sndspd) 2 5) " hours"
"\n" (rtos (/ (/ user_distance sndspd) 24) 2 5) " days"
(setvar 'lunits u-lunits)
I came to the conclusion....I'm a dork.  :lol:
« Reply #14 on: March 03, 2005, 07:50:55 AM »
My stab at it.
(defun c:traveltimes (/ spOl spOs str dist)
  (setq spOl 186000.000 ; miles per second
        spOs 774.98     ; miles per hour
  (textscr)
  (prompt "\nTo calcuate travel times enter a distance in")
  (prompt "\nmiles or kilometers. e.g.1000m(iles) or 1000k(ilometers)")
    (setq str (getstring T "\nEnter distance: "))
      (setq str (strcase str T))
        ((= (vl-string-position (ascii "m") str) (1- (strlen str)))
         (setq dist (atof (vl-string-right-trim "m" str)))
         (princ
           (strcat "Traveling @ the speed of light would take "
                   (rtos (/ dist spOl))
                   " seconds \n"
                   "Traveling @ the speed of sound would take "
                   (rtos (/ dist spos))
                   " hours \n"
        ((= (vl-string-position (ascii "k") str) (1- (strlen str)))
         (setq dist (atof (vl-string-right-trim "k" str)))
         (princ
                   (rtos (/ (* dist 0.621) spOl))
                   " seconds \n"
                   (rtos (/ (* dist 0.621) spos))
                   " hours"
        (T (prompt "You obviously can't follow instructions!!")
           (prompt "\nTry using 1000m or 1000k")
Output
Command: traveltimes
Enter distance: 150000m
Traveling @ the speed of light would take 0.8065 seconds
Traveling @ the speed of sound would take 193.5534 hours
