Author Topic: ERROR: Could not instantiate AecDict!  (Read 5531 times)
CHulse
« on: January 21, 2009, 01:47:42 PM »
Has anyone seen this?
I deleted a few layout tabs and now I get this whenever I change tabs...
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
sinc
Re: ERROR: Could not instantiate AecDict!
« Reply #1 on: January 21, 2009, 02:09:43 PM »
The only thing I can think of is this:
Right-click on the Layout/Model tabs if you have the old-style ones visible, or if not, right-click on the new "Quick View Layouts" button in C3D 2009, and select "Move or Copy".  This should call up the dialog to move layouts, as seen in the attached image.  Move the layouts around, so they are in a different order.
I have seen this clear up problems with layouts.  Unfortunately, not this particular problem, so I don't know if this will help you or not.  But it's the only "trick" I can think of that has cleared up layout problems for me.
CHulse
« Reply #2 on: January 21, 2009, 02:18:25 PM »
Thanks, I'll give it a shot.
Cary Hulse
Matt__W
  • I like my water diluted.
« Reply #3 on: January 21, 2009, 02:18:31 PM »
Have you tried RECOVER and/or AUDIT on the drawing?
Autodesk Expert Elite
Matt__W
« Reply #4 on: January 21, 2009, 02:22:47 PM »
Also...  BIG ARSE LINK
CHulse
« Reply #5 on: January 21, 2009, 02:23:48 PM »
Yep - no change
Moving tabs didn't work either.
This only happens when I move to a layout that has a VP on it. It doesn't seem to have damaged anything I need, just annoying.
Cary Hulse
Bakerman
« Reply #6 on: January 22, 2009, 11:39:34 AM »
I read online that one user with that problem solved it by inserting everything from model space into a new drawing.....if you have a lot of layouts you may not want to try that one.
Another user said that detaching a large xref solved the problem......
« Reply #7 on: January 22, 2009, 11:42:38 AM »
Even if you have a bunch of layouts...just drag them over using Design Center, if that's what it takes to resolve the error.
« Reply #8 on: January 22, 2009, 12:20:17 PM »
OK, the curious me did a little more research, and it would seem that part of your drawing came form some version of ADT.  This guy is part of the problem, and later version (2006) actually has a fix for it in a service pack.
They all sort of point back to Display Manager
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2894142&linkID=9240657
or it is a victim of being 'recovered'
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2879199&linkID=9240657
