Author Topic: Create Multileader Style  (Read 6298 times)
SOURCECODE
« on: December 01, 2011, 04:49:49 PM »
I would Like to create a new Multileader Style
as far as I know I have to open the mleader style dictionary.
Is this correct?
If so How do I create a new MLeader Style Name, and change some properties?
Here is my code so Far
<CommandMethod("NewLeader")> _
    Public Sub NewLeader()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Using trx As Transaction = db.TransactionManager.StartTransaction()
            Dim mleader As MLeaderStyle = trx.GetObject(db.MLeaderStyleDictionaryId, OpenMode.ForRead)
fixo
Re: Create Multileader Style
« Reply #1 on: December 02, 2011, 03:43:20 AM »
Is this correct?
Try this code
Public Shared Sub AddNewMLeaderStyle()
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim tr As Transaction = db.TransactionManager.StartTransaction()
Dim mlstylename As String = "NewMleaderStyle"   '<-- change mleader style name here
Dim txstylename As String = "Romans"   '<-- change textstyle name here
Dim docloc As DocumentLock = doc.LockDocument()
'using (docloc)
Using tr
Try
Dim mldict As DBDictionary = DirectCast(tr.GetObject(db.MLeaderStyleDictionaryId, OpenMode.ForRead), DBDictionary)
If IsDbDictionaryExists(mldict, mlstylename) Then
ed.WriteMessage("Mleader style ""{0}"" exists", mlstylename)
Return
End If
mldict.UpgradeOpen()
Dim mldstyle As New MLeaderStyle()
mldict.SetAt(mlstylename, TryCast(DirectCast(mldstyle, DBObject), DBObject))
mldstyle.ArrowSize = 2.5
mldstyle.ArrowSymbolId = db.Dimldrblk
mldstyle.ContentType = ContentType.MTextContent
mldstyle.DoglegLength = 1.0
mldstyle.DrawLeaderOrderType = DrawLeaderOrderType.DrawLeaderHeadFirst
mldstyle.DrawMLeaderOrderType = DrawMLeaderOrderType.DrawLeaderFirst
mldstyle.EnableLanding = True
mldstyle.FirstSegmentAngleConstraint = AngleConstraint.DegreesAny
mldstyle.MaxLeaderSegmentsPoints = 2
mldstyle.LeaderLineType = LeaderType.StraightLeader
mldstyle.SecondSegmentAngleConstraint = AngleConstraint.DegreesHorz
mldstyle.TextAlignAlwaysLeft = False
mldstyle.TextAngleType = TextAngleType.HorizontalAngle
mldstyle.TextHeight = 2.5
Dim tt As TextStyleTable = DirectCast(tr.GetObject(db.TextStyleTableId, OpenMode.ForRead, False), TextStyleTable)
If Not (tt.Has(txstylename)) Then
Return
End If
Dim txtid As ObjectId = tt(txstylename)
mldstyle.TextStyleId = txtid
'variations:
'#1
'mldstyle.SetTextAttachmentType(TextAttachmentType.AttachmentMiddle,
'LeaderDirectionType.LeftLeader);
'LeaderDirectionType.RightLeader);
'LeaderDirectionType.UnknownLeader);
'#2
'mldstyle.SetTextAttachmentType(TextAttachmentType.AttachmentBottomOfTop,
'#3
mldstyle.SetTextAttachmentType(TextAttachmentType.AttachmentTopOfTop, LeaderDirectionType.LeftLeader)
mldstyle.SetTextAttachmentType(TextAttachmentType.AttachmentTopOfTop, LeaderDirectionType.RightLeader)
mldstyle.SetTextAttachmentType(TextAttachmentType.AttachmentTopOfTop, LeaderDirectionType.UnknownLeader)
mldict.DowngradeOpen()
tr.AddNewlyCreatedDBObject(mldstyle, True)
tr.Commit()
Catch ex As Autodesk.AutoCAD.Runtime.Exception
MessageBox.Show(ex.Message + vbLf + ex.StackTrace)
End Try
End Using
    Public Shared Function IsDbDictionaryExists(ByVal parent As DBDictionary, ByVal dictname As String) As Boolean
        Dim exists As Boolean = False
        For Each edict As DBDictionaryEntry In parent
            If edict.Key = dictname Then
                exists = True
                Exit For
            End If
        Next
        Return exists
    End Function
SOURCECODE
« Reply #2 on: December 02, 2011, 04:44:50 AM »
Thanks Very much Fixo. I have tried using your code but it does not create a new mleader style.
I notice that at no point is the "MLeaderStyleDictionaryId" set to open mode for write.
Could this be the reason?
fixo
« Reply #3 on: December 02, 2011, 12:46:12 PM »
No, MleaderStyledictionary must be open for write,
otherwise you'll get 'enotOpenForWrite' exeption
I have a problem with my code  too
Just interesting, that the converted code on C#
is working good and VB.NET is not
Try this on you machine:
(textstyle named "Romans" must be exist)
       [CommandMethod("Demo")]
        static public void MakemyStyle()
            AddNewMLeaderStyle();
        /// <summary>
        ///                             = Create mleader style =
        /// </summary>
        static public void AddNewMLeaderStyle()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            Transaction tr = db.TransactionManager.StartTransaction();
            string mlstylename = "NewMleaderStyle";
            string txstylename = "Romans";
            DocumentLock docloc = doc.LockDocument();
            using (docloc)
                using (tr)
                    try
                        DBDictionary mldict = (DBDictionary)tr.GetObject(db.MLeaderStyleDictionaryId, OpenMode.ForRead);
                        if (IsDbDictionaryExists(mldict, mlstylename))
                            ed.WriteMessage("Mleader style \"{0}\" exists", mlstylename);
                            return;
                        mldict.UpgradeOpen();
                        MLeaderStyle mldstyle = new MLeaderStyle();
                        mldict.SetAt(mlstylename, (DBObject)mldstyle as DBObject);
                        mldstyle.ArrowSize = 2.5;
                        mldstyle.ArrowSymbolId = db.Dimldrblk;
                        mldstyle.ContentType = ContentType.MTextContent;
                        mldstyle.DoglegLength = 1.0;
                        mldstyle.DrawLeaderOrderType = DrawLeaderOrderType.DrawLeaderHeadFirst;
                        mldstyle.DrawMLeaderOrderType = DrawMLeaderOrderType.DrawLeaderFirst;
                        mldstyle.EnableLanding = true;
                        mldstyle.FirstSegmentAngleConstraint = AngleConstraint.DegreesAny;
                        mldstyle.MaxLeaderSegmentsPoints = 2;
                        mldstyle.LeaderLineType = LeaderType.StraightLeader;
                        mldstyle.SecondSegmentAngleConstraint = AngleConstraint.DegreesHorz;
                        mldstyle.TextAlignAlwaysLeft = false;
                        mldstyle.TextAngleType = TextAngleType.HorizontalAngle;
                        mldstyle.TextHeight = 2.5;
                        TextStyleTable tt = (TextStyleTable)tr.GetObject(db.TextStyleTableId, OpenMode.ForRead, false);
                        if (!(tt.Has(txstylename))) return;
                        ObjectId txtid = tt[txstylename];
                        mldstyle.TextStyleId = txtid;
                        //variations:
                        //#1
                        //mldstyle.SetTextAttachmentType(TextAttachmentType.AttachmentMiddle,
                        //LeaderDirectionType.LeftLeader);
                        //LeaderDirectionType.RightLeader);
                        //LeaderDirectionType.UnknownLeader);
                        //#2
                        //mldstyle.SetTextAttachmentType(TextAttachmentType.AttachmentBottomOfTop,
                        //#3
                        //mldstyle.SetPaperOrientation(true);//<--generate error!
                        mldict.DowngradeOpen();
                        tr.AddNewlyCreatedDBObject(mldstyle, true);
                        tr.Commit();
                    catch (Autodesk.AutoCAD.Runtime.Exception ex)
                        MessageBox.Show(ex.Message + "\n" + ex.StackTrace);
        /// <summary>
        ///                             = IsDbDictionaryExists =
        /// </summary>
        /// <param name="parent"></param>
        /// <param name="dictname"></param>
        /// <returns></returns>
        static public bool IsDbDictionaryExists(DBDictionary parent, string dictname)
            bool exists = false;
            foreach (DBDictionaryEntry edict in parent)
                if (edict.Key == dictname)
                    exists = true;
                    break;
            return exists;
SOURCECODE
« Reply #4 on: December 02, 2011, 01:24:05 PM »
Thanks Fixo. It seems to be working fine now in VB.net.
The problem was as you had suggested.
Romans did not exist.
David Hall
  • Automatic Duh Generator
« Reply #5 on: December 02, 2011, 02:27:53 PM »
What about LineType = Bylayer?  I cant find this setting anywhere
David Hall
« Reply #6 on: December 02, 2011, 03:03:46 PM »
And I also cant figure out how to set it as current style
fixo
« Reply #7 on: December 03, 2011, 09:47:27 AM »
Commander, here is updated code
seemed all bugs is fixed, to be honestly I'm not sure
Anyway all is ok on my end
use short commands MakeEm and SetEm,
agreed, looks ugly but working
Try again:
#Region "Mleader style commands"
        <CommandMethod("SetMyMleaderStyle", "SetEm", CommandFlags.NoInternalLock)>
        Public Shared Sub DemoSet()
            Dim mldict As DBDictionary = Nothing
            Dim mldstyle As MLeaderStyle = Nothing
            Dim mlstylename As String = "MyMleaderStyle"
            Dim getvarObj As Object = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("CMLEADERSTYLE")
            ed.WriteMessage(Environment.NewLine + "Current Mleader style before : {0}", getvarObj.ToString)
            Dim tr As Transaction = doc.TransactionManager.StartTransaction
            Try
                Using tr
                    mldict = CType(tr.GetObject(db.MLeaderStyleDictionaryId, OpenMode.ForRead), DBDictionary)
                    If Not IsDbDictionaryExists(mldict, mlstylename) Then
                        ed.WriteMessage("Mleader style ""{0}"" does not exists", mlstylename)
                        Return
                    End If
                    ' 1st method:
                    mldstyle = CType(tr.GetObject(mldict.GetAt(mlstylename), OpenMode.ForRead), MLeaderStyle)
                    db.MLeaderstyle = mldict.GetAt(mlstylename)
                    ''2nd method
                    '' getvarObj = mlstylename
                    ''Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("CMLEADERSTYLE", getvarObj)
                    '' for dispalying result in final part:
                    getvarObj = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("CMLEADERSTYLE")
                    tr.Commit() '<-- important, otherwise new settings will not stored
                End Using
            Catch ex As System.Exception
                ed.WriteMessage(ex.Message & vbCr & ex.StackTrace)
            Finally
                ed.WriteMessage(Environment.NewLine + "Current Mleader style after : {0}", getvarObj)
                mldstyle.Dispose()
                mldict.Dispose()
            End Try
        <CommandMethod("MyMleaderStyle", "MakeEm", CommandFlags.Redraw)>
        Public Shared Sub DemoCreate()
            Using (docloc)
                Try
                Finally
                    ''do nothing (optional)
                End Try
            End Using
            Dim mlstylename As String = "MyMleaderStyle"   '<-- change mleader style name here
            Try
                Using tr
                        Return
                    End If
                    mldstyle = New MLeaderStyle
                    Dim tt As TextStyleTable = CType(tr.GetObject(db.TextStyleTableId, OpenMode.ForRead), TextStyleTable)
                        Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Does not exist")
                        Return
                    Else
                        Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("TEXTSTYLE", txstylename)
                    End If
                    Dim dbObj As DBObject
                    dbObj = TryCast(mldstyle, DBObject)
                    If dbObj Is Nothing Then
                        Return
                    End If
                    mldict.SetAt(mlstylename, mldstyle)
                    'variations:
                    '#1
                    '#2
                    '#3
                    tr.Commit()
                End Using
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message + vbLf + ex.StackTrace)
            Finally
                mldstyle.Dispose()
                mldict.Dispose()
            End Try
                Try
                        exists = True
                        Exit For
                    End If
                Catch
                End Try
            Next
            Return exists
        End Function
#End Region
David Hall
« Reply #8 on: December 05, 2011, 09:14:41 AM »
Thanks Fixo.  As always, it was something simple I had overlooked.  This is what I ended up with
[CommandMethod("TEPMLeader")]
        public void TEPMleaderStyle()
            Document Doc = acadApp.DocumentManager.MdiActiveDocument;
            Editor Ed = Doc.Editor;
            Database Db = Doc.Database;
            string strMLeaderStyleName = "TEP";
            using (Transaction Trans = Db.TransactionManager.StartTransaction())
                    ObjectId TxtId = ObjectId.Null;
                    TextStyleTable TST = Db.TextStyleTableId.GetObject(OpenMode.ForRead) as TextStyleTable;
                    if (!TST.Has("TEP"))
                        TST.UpgradeOpen();
                        TextStyleTableRecord tsTableRecord = new TextStyleTableRecord();
                        tsTableRecord.Name = "TEP";
                        tsTableRecord.FileName = "Romans.shx";
                        tsTableRecord.IsVertical = false;
                        tsTableRecord.TextSize = 0.09375;
                        tsTableRecord.Annotative = AnnotativeStates.True;
                        TST.Add(tsTableRecord);
                        Trans.AddNewlyCreatedDBObject(tsTableRecord, true);
                    DBDictionary mldict = (DBDictionary)Trans.GetObject(Db.MLeaderStyleDictionaryId, OpenMode.ForRead );
                    if (!IsDbDictionaryExist(mldict, strMLeaderStyleName ))
                        MLeaderStyle objMLeaderStyle = new MLeaderStyle();
                        mldict.SetAt(strMLeaderStyleName, objMLeaderStyle);
                        objMLeaderStyle.ArrowSize = 0.09375;
                        objMLeaderStyle.ContentType = ContentType.NoneContent;
                        objMLeaderStyle.ArrowSymbolId = Db.Dimldrblk;
                        objMLeaderStyle.DoglegLength = 0.09375;
                        objMLeaderStyle.LeaderLineColor = Color.FromColorIndex(ColorMethod.ByLayer,256);
                        objMLeaderStyle.LeaderLineWeight = LineWeight.ByLayer;
                        //objMLeaderStyle.LeaderLineType =
                        objMLeaderStyle.DrawLeaderOrderType = DrawLeaderOrderType.DrawLeaderHeadFirst;
                        objMLeaderStyle.DrawMLeaderOrderType = DrawMLeaderOrderType.DrawLeaderFirst;
                        objMLeaderStyle.EnableLanding = true;
                        objMLeaderStyle.FirstSegmentAngleConstraint = AngleConstraint.DegreesAny;
                        objMLeaderStyle.MaxLeaderSegmentsPoints = 2;
                        objMLeaderStyle.LeaderLineType = LeaderType.StraightLeader;
                        objMLeaderStyle.SecondSegmentAngleConstraint = AngleConstraint.DegreesAny;
                        objMLeaderStyle.Annotative = AnnotativeStates.True;
                        Trans.AddNewlyCreatedDBObject(objMLeaderStyle, true);
                        Db.MLeaderstyle = mldict.GetAt("TEP");
                        Trans.Commit();
        public bool IsDbDictionaryExist(DBDictionary parent, string dictname)
                    exists = true;
                    break;
            return exists;
I still didn't find the Linetype ByLayer part, but that is for another day.
kaefer
« Reply #9 on: December 05, 2011, 10:01:37 AM »
You sure have a funny name for the DBDictionary.Contains() method.
fixo
« Reply #10 on: December 05, 2011, 10:07:57 AM »
Commander,
See the difference:
                        objMLeaderStyle.LeaderLineType = LeaderType.StraightLeader;//it means type of leader lines: invisible leader,spline leader, or straight leader
                        objMLeaderStyle.LeaderLineTypeId = Db.Celtype;// it means linetype in usual terms (an equivalent of lisp variable "celtype" or current linetype will be used)
Hope that make a sence
David Hall
« Reply #11 on: December 05, 2011, 10:13:35 AM »
I borrowed that code and didn't change the names.(thanks Fixo)  Guess I should update it
fixo
« Reply #12 on: December 05, 2011, 10:59:52 AM »
You're very welcome :)
