Author Topic: Creating/Inserting a simple structure.  (Read 1994 times)
spittle
« on: May 09, 2008, 01:25:55 PM »
I want to insert a simple structure, which I plan to switch off. All I really need is a Point, just so i can create a bandset to display the structure's chainage and level.
That's it, but why's it so bloody diffucult!
Ideally I need a solution by monday!
I've created a surface and an alignment and a long section view.
I now want to draw some pipe fittings in the profile view and then at each fitting, insert an invisible structure to show that fitting's invert & chainage, whenever it needs to be moved I can just move the structure to suit. It would be far too complicated to build all the pipe fittings, not that I even know how to use part builder yet!
Any help would be great. Thanks
Dave
Re: Creating/Inserting a simple structure.
« Reply #1 on: May 09, 2008, 02:20:55 PM »
Settings Tab
Pipe Network>>Create a Parts List, add only a NULL or other structure to the Parts List
Then create your Pipe Network from Layout>> Pick your parts list, and choose INSERT structures only, place the structure as required.
Have a nice Day!
(Note I am traveling back to home office this weekend; however if you still need help with this send me an email on Monday morning)
spittle
« Reply #2 on: May 12, 2008, 03:09:42 AM »
Hi
I started doing this and it seemed straight forward enough but when I went to select the new parts list, (and you can see in the Network Layout Toolbar underneath) but it wouldn't let me select ok, or even hit cancel, I can only choose one of the other parts lists created by C3D.
Any more tips are welcome. Thanks
Dave
« Reply #3 on: May 12, 2008, 08:17:57 AM »
Verify the path to your Parts Catalog. This found under the Pipes Pulldown.
spittle
« Reply #4 on: May 12, 2008, 10:13:21 AM »
The path appears to be correct, I've set so I have the option of imperial or metric parts but still no joy trying to use the null structure.
« Reply #5 on: May 12, 2008, 10:47:26 AM »
Please send me a Private Message or use my email address, under my profile so that I can call you and work this out with you. We will then post the solution here.
spittle
« Reply #6 on: May 21, 2008, 03:03:51 AM »
Hey Michael
Did you get to the bottom of why I couldn't insert the null structure?
I've seen the replies to my other thread too and will try and reply once when I get chance to try the suggestions. I'm just a bit stacked up with other work at the moment.
Cheers
Dave
« Reply #7 on: May 21, 2008, 10:30:54 AM »
What service Pack do you have installed?
At some point one could NOT build a network without null structures, and then a Patch was created so that you could create a network with them.  I think in 'fixing' this they broke something, like the ability to actually select a null structure when you want one.
The  fix is to place a structure you do not want. Then delete that structure, the Null structure should then appear.
« Last Edit: May 21, 2008, 10:46:39 AM by mjfarrell »
Dinosaur
« Reply #8 on: May 21, 2008, 11:00:59 AM »
. . .The  fix  work around is to place a structure you do not want. Then delete that structure, the Null structure should then appear.
« Reply #9 on: May 21, 2008, 11:16:47 AM »
Thanks DinØ, I was having trouble replacing "jacked up hack" with something 'constructive' and 'respectfull'.
