Author Topic: Measure By Chord Length?  (Read 3029 times)
BlackBox
« on: May 22, 2016, 06:08:12 PM »
How does one measure a Polyline by chord length?
I thought this was part of the MEASURE Command, but I must be mistaken.
In straight segments, it's easy to copy down. If the point of curvature/tangency is within the desired measured distance, or along a curved segment, etc then the degree of curvature will affect the required arc length in order to reach the chord length.
As example: radial parking spaces between a condo building and a curved centerline.
Old school method was just to draw a circle to determine the location of the next parking stall Haha, but there must be a better way nowadays, no?
TIA
nobody
  • .net stuff
Re: Measure By Chord Length?
« Reply #1 on: May 22, 2016, 08:43:46 PM »
Most guys I know use the measure command with a block...accepting the arc length knowing it's a bit conservative.  Polar array works, if you don't mind using calculator to figure out the angle you want using the radius.  I some guys who used the parcels tools in civil 3d in a trash drawing then just exploding it.  Again though, it uses arc length.
BlackBox
« Reply #2 on: May 22, 2016, 09:02:31 PM »
Thanks, Alien.
I used the Parcel layout tools on a recent subdivision, and ended up having to calculate the required arc length for each-and-every-single radii, and account for which side of the radii the lots were (inside/outside), which was a PITA.
I'm probably going to have to code my own tool for this, but wanted to ask first, as I now end up needing to measure by chord length for every concept plan, or commercial/residential project.
Cheers
nobody
  • .net stuff
« Reply #3 on: May 23, 2016, 05:47:14 AM »
Is frustrating. We had to have some stuff written for things like this. Wish the civil 3d developers would talk to people who know what they are doing before generating stuff like this. I don't think I can recall a situation I needed to layout anything with arc-lengths :/
BlackBox
« Reply #4 on: May 23, 2016, 01:44:30 PM »
Still probably going to have to roll my own in the interim, but posted this anyway:
http://forums.autodesk.com/t5/autocad-civil-3d-ideas/measure-by-chord-length/idi-p/6344450
