Why not set incremental angle to 90° and add 11°, 22° and 45° as additional angles? //Also this isn't really an AutoLISP question as it is a CAD General...
proof of concept attached.You might want to also add the following angles -> 349, 328, 315. This will allow you to go both directions from the last point.
Set your increment angle to 90° and add the 6 additional angles. 11, 22, 45, 315, 328, 349. Granted 180 and 270 will be options but unless you want to go a lisp routine I don't think you can set additional angles without incremental angles.
When relative to UCS is enabled, the last two points determine 0°. If 11/22/45 are your only options, the poly line will only go counter clockwise.
Quote from: Master_Shake on August 12, 2016, 09:21:17 AMWhen relative to UCS is enabled, the last two points determine 0°. If 11/22/45 are your only options, the poly line will only go counter clockwise.Isn't that why we're using relative to last segment? .. Either way what you told him seems to solve the problem .. I just do it differently
