Author Topic: Pressure pipes and fittings  (Read 4690 times)
Fabricio28
« on: August 10, 2016, 02:32:24 PM »
I'm trouble to draw a pressure pipe.
I don't have any lisp to draw polylines with specific angles: 11°, 22°, 45° and 90° (that represent the elbows)
Now I can't insert my elbow's blocks to the pipes.
Anyone could help me, please?
Maybe advice the better way to do that task.
Thank in advance
Fabricio
File attached
Re: Pressure pipes and fittings
« Reply #1 on: August 10, 2016, 02:38:06 PM »
I'd use polar tracking & check relative to last segment.
Fabricio28
« Reply #2 on: August 10, 2016, 02:55:12 PM »
Thank you my friend Ron!  :-D
Fabricio
« Reply #3 on: August 10, 2016, 02:56:38 PM »
Thank you my friend Ron!  ;D
Fabricio
Glad to help :)
Fabricio28
« Reply #4 on: August 10, 2016, 03:38:14 PM »
Fabricio
Glad to help :)
Ron,
I don't know how to set all the angles into polar tracking.
Is that right?
« Reply #5 on: August 10, 2016, 04:01:28 PM »
Use the 'Additional Angles' section of the Polar Tracking dialog.
You may also find it useful to increase APERTURE such that the polar tracking angles are acquired with greater sensitivity.
Fabricio28
« Reply #6 on: August 11, 2016, 07:07:25 AM »
Hi Lee Mac
I can't add all the angles that I need.
I'm a little a bit confused to do that task.
« Reply #7 on: August 11, 2016, 10:03:06 AM »
Don't you just need to add 11.25?
Fabricio28
« Reply #8 on: August 11, 2016, 11:18:11 AM »
Ron,
I don't know how to explain better my task, because my english is very poor.
So I'm attaching a dwg file as example of my task.
It is basically draw a polyline with the correct angles to add the elbows.
Using all possibilities all over 360 degrees
Thank in advance
Fabricio
« Last Edit: August 11, 2016, 11:31:09 AM by FABRICIO28 »
« Reply #9 on: August 11, 2016, 11:43:46 AM »
Strange .. the angles I use for fittings are 11.25 , 22.5, 45 & 90 all are divisible by 11.25 ??
It looks like an easy way to set the used angle is through (setvar 'polarang (angtof "11.25")), then in the options you see:
« Last Edit: August 11, 2016, 12:13:37 PM by ronjonp »
Fabricio28
« Reply #10 on: August 11, 2016, 12:35:35 PM »
You're right my friend,
sorry, worked fine!
Can I set Polar Tracking just for some angles?
Because there are some angles that I don't wanna use, like 34°.
Thank you
« Reply #11 on: August 11, 2016, 01:09:03 PM »
Try this: (setvar 'polarang (angtof "11.25")) & make sure you have relative to last segment checked.
Look into POLARADDANG, POLARMODE & POLARANG variables.
« Last Edit: August 11, 2016, 01:13:56 PM by ronjonp »
Fabricio28
« Reply #12 on: August 11, 2016, 01:25:01 PM »
Worked Perfect!
I'd like to draw polyline just for the correct angle.
I'm attaching a image for example, I don't have elbow for 67° and 68°.
I was wondering if is possible to set polar tracking just for the correct angles to put the elbows.
« Reply #13 on: August 11, 2016, 01:41:23 PM »
I'm lost on what you're really trying to accomplish .. sorry.  :|
Fabricio28
« Reply #14 on: August 11, 2016, 02:09:24 PM »
Not a problem Ron,
I'm getting confused to explain my task too.
