Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Tharwat on July 17, 2010, 09:41:51 AM
Suppose that I have a text consist of inch values, so how can I divide the text i.g :
2"x4"
so the following '(cdr (assoc 0 Entity)) would get the whole text, And I want to times the first and the second number with specific number,
(setq a (car(entsel"\n Select a text :")))
(setq b (entget a))
(if (member (cdr (assoc 0 b)) '("TEXT" "MTEXT"))
(setq c (cdr (assoc 1 b)))
If I want to times the first number with 3 and the second number with 4 and re-insert them
in a text without the inch quotes, So it should become like this:
6x20
Is there any idea ????
Regards
Tharwat
something like this ?
(defun foo (str x1 x2)
(strcat
(itoa (* x1 (atoi (substr str 1 (vl-string-search "\"" str)))))
"x"
(itoa (* x2 (atoi (substr str (+ 2 (vl-string-search "x" str))))))
(foo "2\"x4\"" 3 5) returns "6x20"
Thanks gile.
But how these functions would return the outcome since it is not times by any number.
I have no idea how it works vl-string-search "....." "......." ???
Any explanation or another way to add it in my previous codes ?
Thanking you
Tharwat
(foo "2\"x4\"" 1 1) returns "2x4"
Still not clear at all to me .....
The foo sub requires 3 arguments:
- str the string to process
- x1 the factor to multiply the first number
- x2 the factor to multiply the second number
for the vl-string-search function look at the Developer's Help it will be explain in a better English than I can do.
So could you please add your codes to my previous codes that posted earlier ?????
Many Thanks
Tharwat
Hello gile,
The following Lisp would not complete properly, due to something wrong.
(setq ss1 (ssget '((0 . "TEXT,MTEXT"))))
(if ss1
(setq i 0
total 0
n (sslength ss1))
(while (< i n)
(setq str (cdr (assoc 1 (setq e (entget (ssname ss1 i))))))
(setq i (1+ i))
(strcat
"x"
(itoa (* x2 (atoi (substr str (+ 2 (vl-string-search "x" str))))))))
(print foo)
Best regards
Tharwat
foo have to be defined before it's called.
(strcat
"x"
(if ss1
(setq i 0
total 0
n (sslength ss1)
(while (< i n)
(setq str (cdr (assoc 1 e)))
(setq i (1+ i))
(entmod (subst (cons 1 (foo str 3 5)) (assoc 1 e) e))
(print foo)
That's great gile, you are amazing.
Thanks for your precious time.
Tharwat
