Author Topic: Random Number of Points  (Read 1225 times)
hudster
« on: May 06, 2008, 11:09:34 AM »
I want to create a lisp to draw splines to designate flexible wiring connections.
I can create the lisp so when I click a set number of points, 3 for example, it draws the spline along those points, but I don't have a clue about how to do it for a random number of points.
Can someone give me a pointer please?
gile
  • Marseille, France
Re: Random Number of Points
« Reply #1 on: May 06, 2008, 11:16:32 AM »
Something like this ?
(command "_.spline")
(while (/= 0 (getvar "CMDACTIVE"))
(command pause)
Or, if you have a point list:
(mapcar 'command pt-lst)
(command "" "" "")
