Author Topic: How to lock Xref?  (Read 6146 times)
HasanCAD
How to lock Xref?
« on: July 19, 2011, 03:15:39 AM »
Is there a way to lock Xrefs?
I dont want any one change the settings or detech the Xref.
Daniel J. Ellis
Re: How to lock Xref?
« Reply #1 on: July 19, 2011, 03:25:00 AM »
If you put the xref on it's own layer and lock that layer it will prevent anyone from refeditting the xref or, I believe, detaching it.
The xref itself will still be amendable by opening the xref, though.  You could always set the file to be right-protected through Windows.
dJE
dJE
Rob...
« Reply #2 on: July 19, 2011, 07:20:29 AM »
Setting XEDIT to 0 will also prevent refeditting.
Locking the layer does not prevent someone from detaching the XREF. I'm not sure that this is possible unless you can disable the XREF manager.
CAD Tech
« Reply #3 on: July 19, 2011, 07:39:46 AM »
sounds like a training and education issue...
why not take the time to educate the other users about why they should not molest the XREF file(s)
in the end the time invested will yield higher results
Absent that...
Place a GIANT note in the XREF on a NON Plotting layer as shown below:
DO NOT DETACH, MOVE, or OTHERWISE EDIT this XREF FILE
Rob...
« Reply #4 on: July 19, 2011, 07:44:56 AM »
Education does go a long way but that solution with the text works for one person only. After that I think the text becomes unreadable for some reason.
CAD Tech
« Reply #5 on: July 19, 2011, 07:52:30 AM »
you're joking, right?
« Reply #6 on: July 19, 2011, 08:55:24 AM »
REMOVAL OF THIS XREF FILE IS PUNISHABLE BY DEATH OR UNEMPLOYMENT
WHICHEVER IS MORE PLEASURABLE OR CONVENIENT TO THE ENFORCER
fixed
Krushert
  • FREE BEER Tomorrow!!
« Reply #7 on: July 19, 2011, 09:34:08 AM »
