Author Topic: Comments...  (Read 6003 times)
Glenn R
Comments...
« on: February 22, 2007, 06:56:04 PM »
Found this in a book  :-o
try
    TextReader tr = new StreamReader(locationTextBox.Text);
    try
    { displayTextBox.Text = tr.ReadToEnd(); }
    catch (Exception ex)
    { MessageBox.Show(ex.Message); }
    { tr.Close(); }
catch (System.IO.FileNotFoundException ex)
{ MessageBox.Show("Sorry, the file does not exist."); }
catch (System.UnauthorizedAccessException ex)
{ MessageBox.Show("Sorry, you lack sufficient privileges."); }
Let the discussion begin...
Re: Comments...
« Reply #1 on: February 22, 2007, 07:19:55 PM »
When your thingie is on the block, thats the way I'd probably do it .. the options are limited I think.
Part of the problen with just hacking to get stuff to work is that I forget that it should work "nicely".
I'd be interested in seeing a more elegant way to do that.
Perhaps something like ..
        try
            using (TextReader tr = new StreamReader("TestFileStuff.txt"))
« Last Edit: February 22, 2007, 07:21:09 PM by Kerry Brown »
Glenn R
Re: Comments...
« Reply #2 on: February 22, 2007, 07:30:21 PM »
I agree that it should easy to read, as Bobby would say.
Agreed - you could use a using statement and most of the time I would.
I am, of course, referring to how ugly it is.
The author at this point in the book, exception handling, was talking about try/catch/finally and how variables declared inside the try block are not visible to the catch block...simple stuff. He then proceeds to wrap yet another expensive catch block around the first, nesting them and making it more difficult to decipher.
I would write it like so:
TextReader tr = null;
try
MessageBox.Show("Specified file does not exist.");
MessageBox.Show("Insufficient privileges.");
if (tr != null)
tr.Close();
Far more readable in my opinion.
« Last Edit: February 23, 2007, 09:02:52 PM by Glenn R »
Re: Comments...
« Reply #3 on: February 22, 2007, 08:01:52 PM »
By any chance was it
"Microsoft .NET Framework 2.0 - Application Development Foundation"
Glenn R
Re: Comments...
« Reply #4 on: February 22, 2007, 08:11:09 PM »
< narrows eyes > Maybe... :-D
That's very intuitive Kerry...what made you think of it?
Or you could do it as you suggested Kerry:
try
using (TextReader tr = new StreamReader(locationTextBox.Text))
The using block calls dispose on the streamreader, regardless and dispose calls close().
I would use either approach...depends on what I'm doing at the time.
« Last Edit: February 22, 2007, 08:56:44 PM by Glenn R »
Re: Comments...
« Reply #5 on: February 22, 2007, 08:32:21 PM »
'cause as well as being handsome and witty and intelligent I've been known to mind-read on occasion.
If I could just master grammar I'd be really happy. :lol:
Re: Comments...
« Reply #6 on: February 22, 2007, 08:46:16 PM »
you may have an extra constructor invoked for tr .. yes ?
Glenn R
Re: Comments...
« Reply #7 on: February 22, 2007, 08:59:06 PM »
What extra constructor? 8-)
Damn! I was cutting and pasting in VS for formating < sheepish grin >
Good spot.
David Hall
  • Automatic Duh Generator
Re: Comments...
« Reply #8 on: February 23, 2007, 10:27:50 AM »
I know nobody really has time for writing tutorials, but I wish we had more on the subject of .Net and Autocad.  Part of my frustration is the lack of examples that show/tell WHY things are the way they are or how something should be done.  I myself do not learn by example very well.  I know there are examples that have been posted, but even those are not bullet proof.  Kerry helped me rewrite the examples from Autodesk, b/c they really didn't work as presented.
An example of what I'm referring to, would be the above post.  Just looking at the try/catch block, followed by more catch blocks, went right over my head.  I thought the try catch finally block was "one" block of code.  So what are all the catch blocks below that.  Is that good coding practice or was it thrown together, and it happened to work.  Does any of this make sense?
I guess I'm waiting on a book similiar to the VBA books for Autocad that explain in the most basic of terms how a method works, and give a really small example.  That will probably never be published, so I will have to bang my head against the wall til it works.  Thank goodness for you guys here at the Swamp!
Re: Comments...
« Reply #9 on: February 23, 2007, 11:28:50 AM »
Okay I will try and explain the example of the try/catch/finally as I understand it.
First you open with 'try', this is telling the program to try and do all the things in this area.  Here it is trying to create a new 'SteamReader' process (object), and then use it to read the whole file and show a dialog box of all the content.
Then the 'catch' will catch all errors that are thrown.  I have read that it is good practice to code it like this so that you can show more precise what has happened wrong.  It's kind of like a 'cond' statement in Lisp, and a 'case' (I think this is correct) in VBA.  It will step through each 'catch' and fire the first one that it matches.
The last part is the 'finally' part.  Here is where you do what you have to do to close objects that might be opened in the 'try' part.  Anything that NEEDS to be done, goes in this part.  This part is called no matter what.  The 'catch' part is only called when an error happens, but the 'finally' part is called weither an error happens or not.
Hope that makes some sense, as that is how I understand it.  :-)
If any statements are wrong, please let me know.
Chuck Gabriel
Re: Comments...
« Reply #10 on: February 23, 2007, 11:50:25 AM »
I think Glenn's main point was just that the nested try/catch is ugly, redundant, and confusing, and perhaps that it is a little disheartening to see code of that caliber presented as an "example" for others to follow.
David Hall
Re: Comments...
« Reply #11 on: February 23, 2007, 12:29:12 PM »
I agree.  T.W., your explanation makes sense, and that is how I understand the T/C/F statement as well.  As Chuck said, the example is ugly, and not a good "example" of how to code the statements.
Re: Comments...
« Reply #12 on: February 23, 2007, 12:52:12 PM »
Agreed.
Bobby C. Jones
Re: Comments...
« Reply #13 on: February 23, 2007, 02:08:03 PM »
I hate reading through a book and seeing bad example code.  It taints the experience, even if the overall content is good.  There have been times when I would put a book down when I ran into examples like this.  Now I try to focus on the fact that I probably learn more from seeing the bad than the good.
Now pardon me while I scurry off to see how poorly written the example code in my last few handouts has been :-)
Bobby C. Jones
Glenn R
Re: Comments...
« Reply #14 on: February 23, 2007, 09:00:55 PM »
Spot on Chuck. I'm begining to think the doctors are right ;)
