I have a custom Revcloud command that calls AutoCAD's native REVCLOUD command. It worked in 2014, but now doesn't in 2017.
I just realized that "REVCLOUD" and (command ".REVCLOUD") produce different prompts:
Command: .REVCLOUD
Minimum arc length: 1'-0" Maximum arc length: 1'-0" Style: Normal Type: Rectangular
Specify first corner point or [Arc length/Object/Rectangular/Polygonal/Freehand/Style/Modify] <Object>:
Command: (command ".revcloud")
Minimum arc length: 1'-0" Maximum arc length: 1'-0" Style: Normal Type: Freehand
Specify start point or [Arc length/Object/Style] <Object>:
So, it doesn't appear possible to generate a Rectangular revision cloud using:
(command ".revcloud" "R")
You would have to do something like this:
(setq pt1 "\nFirst corner: "
pt2 (getcorner pt1 "\nOther corner: "))
(command ".RECTANG" pt1 pt2)
(command ".Revcloud" "O" (entlast) "")
The main disadvantage is that you don't see the cloud being generated in real-time, the way you do using the command itself. No a big deal, but I prefer my custom functions to have the same look & feel as a native AutoCAD function.
Is there any way around this?
